TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread >
Like Tree1Likes
Old 08-24-2014, 09:16 PM
  #8401
Taz_S's Avatar
Originally Posted by XXXDad
First I like to PLUG all holes in the rim. Dirt will enter through the rims through the vent holes so plug them . Now the tires all you need is 2 holes opposite from each other. I like the center of the tire so if any water enters it when you clean them will be thrown out when tire is spun. Yes I punch front and rear tires they need to vent so the foam can work. A sealed tire will bounce and be hard.
so what do you used to plug the holes?
Originally Posted by mo
Yes. You can order them 3D printed from my Shapeways store, https://www.shapeways.com/shops/MPP.
I just made a small tweak to it to give more clearance to the motor tabs. I also added a stock replacement waterfall with a fan mount.
You ever thought of making wing mounts that you can use screws instead of clips?
Taz_S is offline
Old 08-24-2014, 10:33 PM
  #8402
SkipGear's Avatar
Originally Posted by gticlay
Heard they charged at 80 amps.
5.13.8 Failure to abide by any and all lithium battery technology charge and discharge rules. At the discretion of the Race Director, the first offense shall result in a round DQ and/or event DQ and the second offense shall result in an event DQ. In the event of DQ from the entire event, the Executive Committee shall review suspension of membership for a period of up to one year from the date of incident.
8.3.2.5.3 Li-Poly battery maximum charge rate shall be 1C. C= charge amp rate. Charge amp rate = mAh capacity/1000=XAmps.
I bet this one slipped by also....
8.3.2.5.8 All Lithium Polymer packs used for motor power must be charged or discharged inside a “Lipo Sack” or similar fire mitigation device proven to withstand a minimum of a 8.4v 5000mAh for 2s or 14.8v 5000 mAh for 4s Lithium Polymer pack failing destructively without showing external flame. Charging or discharging of multiple batteries in a single “Lipo Sack” is not allowed. Charging or discharging of multiple li-42 poly battery packs simultaneously shall be done with each battery in its own individual fire mitigation device.
Just sayin'
SkipGear is offline
Old 08-24-2014, 11:20 PM
  #8403
gticlay's Avatar
Trader Rating: 14 (100%+)
Talking
Originally Posted by Wildcat1971
lol, what?
Oh, was just starting rumors.
gticlay is offline
Old 08-25-2014, 01:05 AM
  #8404
Jinggoy's Avatar
Hi, anyone know where i can get this -2.0 Mid-Motor Brass Anti-Squat Weight Block?
thanks
Jinggoy is offline
Old 08-25-2014, 01:35 AM
  #8405
Try Cream Extreme from this thread. I got mine from him. Great service and great product.
http://www.oople.com/forums/showthre...t=74468&page=9
magnushedqvist is offline
Old 08-25-2014, 07:37 AM
  #8406
R/C Tech Elite Member
XXXDad's Avatar
Trader Rating: 198 (100%+)
I use black electrical tape or an old sticker
Using the stock wing mount you cut/grind off the stud and drill a hole and use a Avid wing washer . Avid also makes Alu. Wing mount's with screw in it.
It works perfect I will take a pic of this mod and post.
XXXDad is offline
Old 08-25-2014, 07:40 AM
  #8407
XXXDad's Avatar
Thumbs down Yes Cream.. should be thumbs UP not down>
Cream is the original inventor/maker of this brass MM weight system , here in the USA Rocket RC makes them . The link is in my signature.
XXXDad is offline
Old 08-25-2014, 09:02 AM
  #8408
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Originally Posted by Clyne579
Does anyone know what the kick angle on the HRC front pivot block is TLR334015? Want to mess with some HRC setups. Thanks!
25*
Frank Root is offline
Old 08-25-2014, 12:37 PM
  #8409
Taz_S's Avatar
Got mine in a few days ago. Going to run the car first then swap them out and feel the different. He dose of some stock so e-mail him. He has not fix the site yet.
Taz_S is offline
Old 08-25-2014, 11:39 PM
  #8410
kman16jr's Avatar
Trader Rating: 56 (100%+)
Default steering rack
Hey guys i have a 22 2.0 with a savox 1251mg servo and when i have my rack perfectly centered at zero degrees toe it cant get full steering unless i go to like +2 toe. Basically can i achieve full steering in this car at zero degrees toe with my savox 1251mg?
kman16jr is offline
Old 08-26-2014, 12:07 AM
  #8411
Hi,
I run the same servo and similar setup in my 22 and found that I needed to put the No.2 servo spacers between the servo and the mount to make sure I had full steering range.
FrogPrince82 is offline
Old 08-26-2014, 07:56 AM
  #8412
TLRacing
Frank Root's Avatar
The low profile servos don't get as much throw as a full size servo, especially that Savox servo. Also, what radio do you use? Some radios only go to 120% EPA's and not 150%.
Old 08-26-2014, 08:34 AM
  #8413
well the Hobbywing v3.1 stock spec esc just won Stock nationals in 2wd buggy with a Schuurspped motor. So that must be a winning combo.
Maybe the JC Indoor nats but at the ROAR Nats it was a Hobbywing with a Trinity D4 that won 2wd buggy
punkracer24 is offline
Old 08-26-2014, 08:52 AM
  #8414
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
You are correct. I think the Schuurspeed was in the TQ car, which also sported a HW 3.1 esc.
Wildcat1971 is offline
Old 08-26-2014, 08:53 AM
  #8415
Smile
hello , I am new to rc with a 22.2 that i run in France on astro (verry hight grip when dry , none when wet) . I would like to know if it is good to raise the gear box 1mm like with the 22.1 .
thank you in advance.
joss9999 is offline
