TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread
#8296
Anyone using the HD Ti turnbuckles kit? Does it require different studs? Is it overkill for the 22?
http://www.amain.com/Team-Losi-Racin...-Kit-6/p265910
#8298
#8299
#8301
Mainly a 1/8 nitro guy, I have a RM TLR 22 2.0 I run, but not raced yet, that works really well thanks to info found here.
I would like to try MM, but am overwhelmed by the multiple setup options, add-ons required.
I run at the SDRC Raceway track in San Diego.
Anyone familiar with the this track and have a base setup ( including must have options) that will work well there?
Maybe Frank? Have you run there with good results?
Thanks,
Mark
Thanks,
Mark
#8302
#8303
Are there any differences in the shock bodies from the 1.0 to the 2.0?
Really SCT related as I want to rebuild my sons SCT with the seals that come with the 2.0 buggy.
Thanks,
Joe
Thanks,
Joe
#8305
I'm having problems with the ballcups popping off my new build with the HD set when I try to adjust them. I usually use beeswax chap stick but this time used the black thrust bearing grease as one of you guys recommended. It's like they are too long.
#8307
#8308
Ballcup wrench
#8309
R/C Tech Elite Member
Put the turnbuckle in a drill
Take out your drill take off ball cup end, put bare turnbuckle into chuck. Then work the end on and off in and out at least 6 times with some lube. Flip it,Then do the other side. No more popping off.
Get this ^^^
I hear yea..I picked up a ballcup wrench with my 22 2.0 build and it's my life saver. I don't use it often but when i do it saves some of my sanity.
Ballcup wrench
Ballcup wrench
