TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread >
Like Tree1Likes
Old 08-08-2014, 08:11 AM
  #8236
Ultraspeed84's Avatar
Trader Rating: 45 (100%+)
For you guys wanting to try maifields setup I hope ur paying attention to the fact he drilled another hole on the rear shock tower..
Attached Thumbnails TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread-maifield.jpg
Ultraspeed84 is offline
Old 08-08-2014, 08:54 AM
  #8237
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Originally Posted by Dale.0
I'm going to try may fields set up. But don't have gold kyosho springs yet. What is the closest TLR spring?
Silver LF, but it is a little softer than Kyo Gold. We are looking into this.
This is on the setup sheet as well -
Frank Root is offline
Old 08-08-2014, 08:55 AM
  #8238
gticlay's Avatar
Trader Rating: 14 (100%+)
One of the first things people noticed! All kinds of fun new stuff. I put the 1.0 front arms on my build and need to drill the rear tower next.
gticlay is offline
Old 08-08-2014, 08:59 AM
  #8239
J@UNE's Avatar
Would a combination of std/1.0 front spring (green or blue) would be similar or they are too progressive for LF Rear?
J@UNE is offline
Old 08-08-2014, 09:02 AM
  #8240
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
The std springs are pretty progressive. you can feel the difference in your hands.
Wildcat1971 is offline
Old 08-08-2014, 09:06 AM
  #8241
Originally Posted by Wildcat1971
Worked on my kids car last night. The sworkz wing came in as well as some plastics to replace to freshen up the car a little. The wing seems to work fine, but after trimming it is 12g heavier. And IMO sits a little low. I might see if I can use an AE wing spacer to lift it. While I was at it, I cut and drilled out the wing mounts to get rid of the body clips. I took a couple pics and i think it came out pretty good. The wing was like $8 and some change from amain.
Is that added brass below the motor cover?
potatobed409 is offline
Old 08-08-2014, 09:17 AM
  #8242
no, the only brass is the front kick spacer.
Old 08-08-2014, 09:24 AM
  #8243
TLRacing
Frank Root's Avatar
Those would be way too stiff, you're looking at Orange or Silver fronts. Ultimately, the frequency is really important and I think you'll be better off with Silver LF rather than standard springs.
Old 08-08-2014, 09:52 AM
  #8244
gticlay's Avatar
I have my build about 75% done now. The 2.0 kit has a lot of really great features and refinement my hybrid "1.75" didn't have. Just need to build diff, shocks...
Attached Thumbnails TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread-bodywrapcropped.jpg
gticlay is offline
Old 08-08-2014, 07:04 PM
  #8245
Stevomatik's Avatar
Looks good what color you gonna paint the clear parts?
Stevomatik is offline
Old 08-08-2014, 07:26 PM
  #8246
gticlay's Avatar
Not sure. Maybe blue? To be honest, the wrap leaves a lot to be desired out back. I sent them an email and picture because it does have an abnormal amount of clear.
gticlay is offline
Old 08-08-2014, 10:33 PM
  #8247
jbrooks39's Avatar
Toe doesn't affect side bite, but less anti-squat has more side bite from my experience.
Will less toe-in help a car to pivot or free it up in rotation?
Ex: going from 3.5 to 3.0 rear toe.
jbrooks39 is offline
Old 08-09-2014, 06:02 AM
  #8248
offroad racer's Avatar
Hey guys I have a question that I hope you can help me with. I have the 1.0 with a bunch of 2.0 upgraded parts and I run on an indoor clay track that I would say has medium to medium high bite. I am running rear motor with my battery pack all the way back. The problem I am having is in the turns whenever I tap the brakes more than about 20% my car's tail whips around and kills whatever line I had going. It isn't a slight-whip, more like 180-225* every time. Do you think this could be due to the fact that I have all the weight in the back and I should try maybe moving the battery forward?
offroad racer is offline
Old 08-09-2014, 07:33 AM
  #8249
Try adding a little bit of drag brake. This can help slow the car down to help carry speed through turn and possibly eliminate the need to hit the brakes.
Beaker151 is offline
Old 08-09-2014, 08:11 AM
  #8250
seth556's Avatar
Trader Rating: 43 (100%+)
Check all your bearings, one may just be bound up.
seth556 is offline
