TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread >
Like Tree1Likes
Old 07-15-2014, 10:02 AM
  #7966
Casper's Avatar
Trader Rating: 34 (100%+)
Originally Posted by Matt Trimmings
Ah yeah....clearance and the lower shock mount. Was referring to the location of the outer shock mount. 1.0 arms have 3 mounting locations and the 2.0 have 2. Not the slight angle change of the shock.
Rear arms added a new inner hole. I thought the front arms have the same holes as in they did not move.
Casper is offline
Old 07-15-2014, 10:05 AM
  #7967
Matt Trimmings's Avatar
Trader Rating: 170 (100%+)
The front arms deleted a hole (outer, correct?). The rear arms added a hole (inner).
Matt Trimmings is offline
Old 07-15-2014, 10:07 AM
  #7968
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
I believe that is correct. The reason was, no one ever used the outer hole. I guess no one told Ryan that the outside hole was never used
Wildcat1971 is offline
Old 07-15-2014, 10:11 AM
  #7969
Casper's Avatar
Yep. Sorry. I forgot about that.
Casper is offline
Old 07-15-2014, 10:14 AM
  #7970
Guys, on the front 22 2.0 a-arms, the outer hole was eliminated (no longer an option) leaving only the middle & inner hole to use on the 2.0 arms. (Like the other guys said, the 2.0 front arms was also moved forward for shock clearance when used with the updated 2.0 slider rack)
For clarification the 22 1.0 front a-arms has all 3 of outer, middle, & inner holes. (The 2.0 front arm only has two, which are middle, inner holes)
4wd Racer is offline
Old 07-15-2014, 10:44 AM
  #7971
gticlay's Avatar
Trader Rating: 14 (100%+)
So what we know so far - short chassis of unknown length, 1.0 a-arms, +35g brass front pivot mount, we don't know what springs or what's inside the shocks yet, new hole drilled in back tower, a "mock square" pack weight and distribution wise, Silencer body that appears to have a rear wing design, shorty servo... that's not all that bad.
Casper - Dunford - Root - anyone that knows - are you guys running an aluminum idler gear between the top idler and diff gear? I noticed Kyosho promotes that for the smoothest transmission so I was curious if you guys do that too.
gticlay is offline
Old 07-15-2014, 10:49 AM
  #7972
Kyosho promotes overly priced cars
Old 07-15-2014, 10:52 AM
  #7973
J@UNE's Avatar
Originally Posted by seth556
On this picture you can see he must have a hard time getting to bottom screw on the gear cover, looks like the side pod is in the way...
I know I couldnt access thats screw with a -8 chassis...
http://www.rctech.net/forum/10396055-post14346.html
J@UNE is offline
Old 07-15-2014, 10:53 AM
  #7974
Casper's Avatar
Dunford played with this a little recently and was using an alum idler against the diff and it freed up the tranny a little. This helps stay away from metal to metal contact as well.
Seems to be working well. not really needed for strength in the buggy but seems to have freed up the tranny slightly.
Casper is offline
Old 07-15-2014, 11:03 AM
  #7975
gticlay's Avatar
Cool, thanks. I'll give one a try too then. I know it's not for strength.
gticlay is offline
Old 07-15-2014, 12:10 PM
  #7976
So what does TLR do in the current situation, if maifield prefers the feel and shock location of the 1.0 arm but as Frank stated they are not making them anymore? This is totally just a want to know question, I don't drive a 22 but I do enjoy seeing truely modified cars. Like the latest sct setup, uses parts from two other cars, that's cool to see.
CaseyD is offline
Old 07-15-2014, 12:18 PM
  #7977
Well..The 22 has had a lot of front end geometry changes. And in the past, "maybe" the hole was not used, but may again become wanted with the current changes the drivers like. My guess? Tlr 22 3.0. comes with bell cranks, revised 3 hole arms, new spindles, new esc mount (like the 22 sct) and maybe a revised chassis. My guess is, it will be like the 22sct and only come with one configuration. The conversion for MM/RM will be optional. IMO, they have done or will have done enough development to justify a 3.0 kit next year, if they decide to go that route. Right now they are trying to get the sct truck out. So I doubt a 3.0 kit this year.
Old 07-15-2014, 03:07 PM
  #7978
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
We also did run 1.0 arms, to use the additional mounting hole outside in the arm. For the 2.0, this hole was eliminated since the shock (spring) and turnbuckle interfered with each other quite bad, as they did some on Ryan's car. Although they don't fit perfectly, we may be bringing some of these back into stock as a tuning option - just know there will be some interference at lock.
Frank Root is offline
Old 07-15-2014, 03:15 PM
  #7979
SkipGear's Avatar
Won't the ballcups coming out for the bellcrank steering eliminate some of the interference issues, making it a more viable tuning option?
SkipGear is offline
Old 07-15-2014, 04:15 PM
  #7980
TLRacing
Frank Root's Avatar
The bell cranks needed more clearance than the slider rack, which the ball cups were needed for. This will not be enough to clear the shock in the outer hole on the arm as well. You can trust me when I saw we've looked into all of this.
