TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread >
Like Tree1Likes
Old 07-02-2014, 06:31 AM
  #7816
brad996's Avatar
Originally Posted by hacker07
I would like to add to this a little. One thing you will also want to do if you try this is to raise the rear tower. The car doesnt have enough up travel and wont land correctly if you dont. I have mine up 1.5mm and I think that is plenty.
What are you using to shim the tower up ?
brad996 is offline
Old 07-02-2014, 08:01 AM
  #7817
I am using the countersunk washers from the TEN platform that hold the nitro engine in, lol. They fit over the keys perfect.
hacker07 is offline
Old 07-02-2014, 08:48 AM
  #7818
Casper's Avatar
Trader Rating: 34 (100%+)
Originally Posted by treemagnet
Hey everyone, quick question. Do TLR 22 wheels fit on the older XXX cars?? Or have they changed the design?
You will need to figure out how to get 12mm hexes on the XXX but if you can do that you should be able to use them. I don't think the 22 hexes will fit on the XXX axles but never tried. You can use XXX wheels on the 22 with stuff included with the kit but going the othe way is a little harder but I am sure doable. Might have to drill out some hexes.
Casper is offline
Old 07-02-2014, 09:01 AM
  #7819
Trader Rating: 28 (100%+)
Sir,
DO you have a part number for the washers and a picture of the car and how you installed it? Do the washers go between the chassis and tower?
Thanks,
Dave
dbracn is offline
Old 07-02-2014, 09:32 AM
  #7820
Casper's Avatar
Originally Posted by dbracn
Sir,
Thanks,
Dave
There are small nubs that lock the tower to the camber block in this case.
I think these come with LOSB5033.
http://www.horizonhobby.com/products/LOSB5033
Not sure if you can get them another way and I am sure this is not the only way to do this just what Ryan found that worked in his box of stuff!
So they just go between the tower and the camber block with the cone side up so the shock tower nubs fit in the cone hole. You can shave off the index numbs on the bottom of the tower as well and just use normall spacers. There are a few ways to do this.
Casper is offline
Old 07-02-2014, 09:30 PM
  #7821
wvrcracer's Avatar
Could someone direct me to a rear motor set up for a really slippery dusty dry outdoor track.(mod) Tried the latest dunford setup and it works ok but still need more side bite and forward bite. How much weight is normally added to rear motor setup.
wvrcracer is offline
Old 07-02-2014, 09:47 PM
  #7822
R/C Tech Elite Member
XXXDad's Avatar
Trader Rating: 198 (100%+)
XXXDad is offline
Old 07-03-2014, 02:04 AM
  #7823
treemagnet's Avatar
Trader Rating: 17 (100%+)
Thanks for the reply Casper. Seems like a little bit too much fussing around for me. Might just buy a 22 instead
treemagnet is offline
Old 07-03-2014, 11:25 AM
  #7824
Now theres a man with a plan, haha!
hacker07 is offline
Old 07-06-2014, 06:22 PM
  #7825
Jerm13's Avatar
Trader Rating: 36 (100%+)
Originally Posted by XXXDad
Looks like the 22-4 rear arms. That is a trick looking set up. I just got doing mine. I ended up getting the shocks in the slot but I think I may put spacers on the front like you.
So here is my question. Did the rear sit higher up than it did with the stock arms? and what did you end up doing for shock oil?
Jerm13 is offline
Old 07-07-2014, 05:42 AM
  #7826
XXXDad's Avatar
Arrow
So here is my question. Did the rear sit higher up than it did with the stock arms? No after the install install it was at 24mm ride height just like it was set before.
[B]Shock oil the same too I run 1.6 two hole with white LF spring[ and 25 oil Rear[B]
XXXDad is offline
Old 07-07-2014, 09:32 AM
  #7827
Jokermayhem's Avatar
Hey guys...i haven't raced in about 6 months with my 22 2.0 RM buggy. What is the latest mods and latest setup for outdoor RM dusty clay setup? Thank you
Jokermayhem is offline
Old 07-07-2014, 09:35 AM
  #7828
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
Hardly been any RM talk. Mostly guys playing with MM. No "new" mods, but the TLR rack comes out next month.
Wildcat1971 is offline
Old 07-07-2014, 10:09 AM
  #7829
Trader Rating: 18 (100%+)
Quick question for everyone... I've only used the Ball Diff in my mid motor 22 2.0. But I have heard of some using the gear diff from the RTR kit and adjusting diff fluid as needed.
Have any of you tried this with success? Notice any significant differences over the Ball Diff?
I only ask because I am due for a Diff rebuild soon and started looking at all my options. I used to run the Team C evo and that platform was better with the gear diff.
BensPro2 is offline
Old 07-07-2014, 10:12 AM
  #7830
Carranza76's Avatar
if you are running 17.5 stock the gear diff is a good option with just black grease. if mod i'd stick with the ball diff.
Carranza76 is offline
