TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread >
Like Tree1Likes
Old 06-10-2014, 12:57 PM
  #7696
Thanks what rm setup would you recommend and also what would running a softer or firmer closed cell insert do?
Rcracer20 is offline
Old 06-10-2014, 01:34 PM
  #7697
I'm having some problems jumping my 22 2.0. I have Frank Roots RM setup, running on a medium bite dirt track that is shared with 1/8 scale buggies. The only changes I've made is 0 degree caster blocks. The 1/8 scales buggies are beating the jump faces up pretty bad and because of it, my 22 is jumping very erratic. Twisting to the left and right every time. I noticed the other buggies are more consistent then mine. Any suggestions??
potatobed409 is offline
Old 06-10-2014, 03:50 PM
  #7698
goehm's Avatar
Trader Rating: 45 (100%+)
Hard to tune for beat up jumps; I'd suggest adjusting your line to hit the best part of the jumps faces. Maybe raise ride height if everything is blown out...
goehm is offline
Old 06-10-2014, 04:23 PM
  #7699
Trader Rating: 31 (100%+)
I (and others) are having the same problem at our track as well. I'm considering upping the shock oil 2.5-5wt all around to see if it will help it to stay on top of the ruts a little better.
joncmack is offline
Old 06-10-2014, 04:36 PM
  #7700
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Try going back to 4 hole pistons, 55's front and rear. They won't pack up as much and might be better on the bumpier surface.
Frank Root is offline
Old 06-10-2014, 04:42 PM
  #7701
I was thinking of going down a little with shock oil to soften the damping. Is your track about 30 minutes south of you??
Old 06-10-2014, 05:00 PM
  #7702
Yes, it is....The Grove in Rock Hill, SC.
joncmack is offline
Old 06-10-2014, 06:29 PM
  #7703
Thats the track I'm talking about.
Old 06-10-2014, 11:52 PM
  #7704
I've seen a lot of setups recently with 55 pistons instead of the 1.6. What differense is there in handeling between those two?
magnushedqvist is offline
Old 06-11-2014, 09:55 AM
  #7705
bcadman's Avatar
Trader Rating: 65 (100%+)
Default Same thing happens to me too
The same thing happens to my 22.
I run at The Grove too!
I thought it was just me.
bcadman is offline
Old 06-11-2014, 11:46 AM
  #7706
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
Congrats to JP for winning the MS Benefit Race at Delaware Ohio RC Raceway. But why not run MM. Rctech says MM is best everywhere
Wildcat1971 is offline
Old 06-12-2014, 07:07 PM
  #7707
theproffesor's Avatar
Trader Rating: 66 (100%+)
I have a question about the new bell crank steering. Since it comes with updated spindles will 1. Those spindles be available seperate, and 2. Will the rear hubs be made available seperste from the current 2.0 spindles. I would hate to have to purchase the outdated front spindles to replace a broken rear hub.
theproffesor is offline
Old 06-12-2014, 07:59 PM
  #7708
brad996's Avatar
The 55 piston feel very close to 1.6 to me but the car doesn't get upset as easy in the bumps. The only thing I didn't like as well about the 55 is they don't land as well off bigger jumps or if you over jump and flat land the buggy
brad996 is offline
Old 06-12-2014, 08:21 PM
  #7709
Trader Rating: 21 (100%+)
You will be able to get the bell crank spindles separate but will have to let Frank or someone else comment about the rear hubs if they will be changed.
Brian L is offline
Old 06-13-2014, 03:53 PM
  #7710
I really hope they sperate them aftwr the new steering comes out. It qouls be ridiculous to have a bunch of useless 2.0 spindles laying around
