TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread >
Like Tree1Likes
Old 06-07-2014, 11:06 AM
  #7681
Drove a 22 2.0 Thursday at my local track and bought one that night. Can't wait to get it going. I haven't done 2wd buggy in a long time since my BK2. Looking forward to getting it going.
Any ESC's and motor combos you guys suggest? It'll be ran in the mod class.
Brushless Corey is offline
Old 06-07-2014, 12:56 PM
  #7682
I run a Viper VTX10R with a Reedy Sonic 8.5, awesome combo
rippen is offline
Old 06-07-2014, 02:47 PM
  #7683
JeepSpeed's Avatar
How about for stock 17.5 class racing? I was debating between these two systems
Tekin RS Gen 2
http://www3.towerhobbies.com/cgi-bin...?&I=LXDHNY&P=7
and
LRP Flow Works Team
http://www3.towerhobbies.com/cgi-bin...&I=LXDYHU&P=ML
Sounds like both are really good systems, but I think I'm leaning towards the Tekin. The track I'll be racing is an indoor clay track.
JeepSpeed is offline
Old 06-07-2014, 02:59 PM
  #7684
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
I prefer Tekin....awesome support and great power and feel...
Matt M. is offline
Old 06-07-2014, 04:08 PM
  #7685
Trader Rating: 31 (100%+)
I've had great experience with the Hobbywing V3.1 Stock Spec ESC when running 17.5:
http://www.falconsekido.com/products...ock-v3-1-black
Paired with either a Trinity D3.5 (non ROAR rules) or R1 Wurks 17.5 and it is as fast or faster than anything on the track.
*I even accidentally plugged the battery in backwards once and despite sparks/smoke....it still works, and didn't even have to be re-calibrated (probably need to solder on new capacitors though)
joncmack is offline
Old 06-07-2014, 06:22 PM
  #7686
Trader Rating: 32 (100%+)
I run viper vtx esc and 7.5 or 10.5 depending on track. Super smooth with lots of power and run cool. Also great support from team drivers and managers!
urluzn is offline
Old 06-07-2014, 06:30 PM
  #7687
Default x
X
Attached Thumbnails TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread-10268610_616602711762261_1357069196871358729_n.jpg
shumway is offline
Old 06-07-2014, 06:33 PM
  #7688
I have be fast diffs front feels a bit crunchy after first race any suggestions, front seemed to get tighter for some reason?
shumway is offline
Old 06-07-2014, 07:24 PM
  #7689
billdogg's Avatar
Trader Rating: 15 (100%+)
I put on a TLR cab forward body on my RM 2.0. The body is hitting the servo wire plugs coming off my Speed Passion Reventon R, and not letting the body sit fully down. Do they make shorter plugs, or 90' plugs that would help? Or could I cut the tray, and run the ESC on the chassis?
billdogg is offline
Old 06-07-2014, 08:38 PM
  #7690
I run esc on chassis.
urluzn is offline
Old 06-08-2014, 05:49 PM
  #7691
theproffesor's Avatar
Trader Rating: 66 (100%+)
Does anyone cut the air vents out under the front window in the cab forward body?
theproffesor is offline
Old 06-08-2014, 07:35 PM
  #7692
billdogg's Avatar
I did on my MM car. I also mounted the switch for my ESC on top of the servo, so it sits right under that vent. I don't have to remove the body to power it on/off.
billdogg is offline
Old 06-10-2014, 04:02 AM
  #7693
Whats a good mm setup to start out with for this track. Its med to high bite. Thanks
Attached Thumbnails TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread-image.jpg
Rcracer20 is offline
Old 06-10-2014, 04:04 AM
  #7694
Heres the other half
Old 06-10-2014, 10:02 AM
  #7695
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
http://www.tlracing.com/ProdInfo/Fil..._Mid_Motor.pdf
Frank Root is offline
