TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread >
Like Tree1Likes
Old 05-20-2014, 12:47 PM
  #7606
Carranza76's Avatar
Originally Posted by Stevomatik
Yea MM is just heavier than RM cuz yours is way lighter than mine. Makes sense when I think about the bigger gear case, extra idler an bearings, and I'm running the esc on top Of the battery.
But geez my buggy sure does feel better in stock with a battery that's 20 grams lighter
Are you using any aftermarket parts for your mid motor configuration?
Carranza76 is offline
Old 05-20-2014, 03:06 PM
  #7607
Stevomatik's Avatar
No I'm not using any aftermarket parts for the reason of weight... Actually the only aftermarket part I have in there is the jconcepts front axle conversion... However I did do the the rear motor esc tray mod for mm config which might be adding a lil weight.
But if you run the esc on top of the battery there's extra components you need to use anyway so it probably evens out.
I was just wondering how much grams it saves from stock to mip puck system. I also know rotating mass makes a bigger difference as well
Stevomatik is offline
Old 05-20-2014, 05:45 PM
  #7608
gprcmx312's Avatar
I used to have an original 22 and I ran mid motor with a shorty pack. I have not had time to look build my 2.0 to know if the shorty will work. I have heard from others that it will not and just making sure on here. Thanks
gprcmx312 is offline
Old 05-20-2014, 06:03 PM
  #7609
LosiRacer33's Avatar
I run my shorty pack under the same brace as the saddles. A little roomy on the sides but foam fills that void nicely. If I need a little bit more traction I run the saddles and that puts the extra weight down low. Run shorty when traction is high.
LosiRacer33 is offline
Old 05-20-2014, 07:27 PM
  #7610
R/C Tech Elite Member
XXXDad's Avatar
Trader Rating: 198 (100%+)
Arrow This is how I do it
MM 2.0 using RocketRC parts
XXXDad is offline
Old 05-20-2014, 08:41 PM
  #7611
Does anyone run avid slipper clutch, top shaft and motor plate? If so notice any differences advantages or disadvantages?
Goldfish is offline
Old 05-20-2014, 09:18 PM
  #7612
I have a question about the new steering bell cranks,
Is any of it aluminum????
S.TRIPP77 is offline
Old 05-20-2014, 09:33 PM
  #7613
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
yeah, the posts
Why do people love aluminum?
Wildcat1971 is offline
Old 05-20-2014, 09:46 PM
  #7614
Originally Posted by Wildcat1971
yeah, the posts
Well I don't know. I don't have to have it I guess, losi does make real good 1/10 plastic so I don't really need it.
Old 05-21-2014, 11:22 PM
  #7615
corn_bread's Avatar
Trader Rating: 41 (100%+)
anyone know if i can use my associated b4 rear wheels on the losi 22 2.0
corn_bread is offline
Old 05-21-2014, 11:27 PM
  #7616
ps71's Avatar
http://www.amain.com/product_info.ph...-TLR22-B42-RB6
This one does not fit, i had to put a shim on the outside of the hex to get it tigth
ps71 is offline
Old 05-22-2014, 05:47 AM
  #7617
Wildcat if you are having issues at W3 go talk to Matt Moeller or Chris Schneider in the shop. Both of their 22s are great in stock.
Gitsum is offline
Old 05-22-2014, 06:44 AM
  #7618
ok, sounds good. I worked on it couple a couple hours last night and it still 1-1.5 seconds per lap slower than my B5. I will hit them up. thx
Old 05-25-2014, 10:14 AM
  #7619
Trader Rating: 31 (100%+)
So for each week's race lately, I've decided to try something different on my buggy. Last week, I gave Frank Root's setup a try. It felt pretty good, something just felt off to me. This week, I'm going to try a different layout on the chassis and mount the esc down low. I had an extra front battery brace, so I drilled it and mounted it to the top of the rear bulkhead supports, which makes a very nice "battery box". I wanted to try moving my lipo forward anyway to hopefully get more overall steering (also added 1mm more droop in rear than front). Here's a pic of my new layout (low profile servo helps: Solar D770....$17 from Hobbypartz). This is for a medium traction, outdoor track.
joncmack is offline
Old 05-25-2014, 12:54 PM
  #7620
rob martin's Avatar
Trader Rating: 66 (100%+)
Wildcat check ur pm
rob martin is offline
