TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread >
Like Tree1Likes
Old 04-02-2014, 08:31 AM
  #7216
Carranza76's Avatar
Post here what you need and someone will be more than willing to help with what you can do to achieve it.
Carranza76 is offline
Old 04-02-2014, 05:28 PM
  #7217
jsrocket13's Avatar
Trader Rating: 27 (100%+)
Can anyone tell me where to find a titanium screw kit for my car I'm building one for stock racing.
jsrocket13 is offline
Old 04-02-2014, 05:53 PM
  #7218
Bobby Z's Avatar
Originally Posted by drepus
This sounds backwards to me but i may be reading it wrong.
If you install the spacers on the bottom of the caster block that would lower the axle and have the same effect as lengthening the shock. More rear grip and less steering on corner exit.
If you install the spacers on the top of the caster block that would raise the axle and have the same effect as shortenning the shocks. Less weight shift/less rear grip on power. More on power steering.
I had to read this twice and correct my response
spindles go around the caster block and not inside it like it did in older gen buggies.
So spacers on top is higher axle height and spacers on bottom is lower axle height
Bobby Z is offline
Old 04-02-2014, 07:46 PM
  #7219
vito's Avatar
shorty or saddle pack in mid motor?
vito is offline
Old 04-02-2014, 08:30 PM
  #7220
Guch's Avatar
Default mid motor battery choice
I think it depends on how long your races are. I see some setups have added weight with shorty packs. The extra weight of the saddle or new square packs seem to lessen the need for adding as much additional weight. You may need to add some weight for traction no matter what. I have no additional weight besides the rocket racing front brass pivot for the rear arms and I run a shorty pack. She is a 3800 mah pack and charge her between every race. I may go with SMC's new square pack soon due to my shorty being almost three years old.
Guch is offline
Old 04-03-2014, 08:04 AM
  #7221
sduffy77's Avatar
Trader Rating: 24 (100%+)
Hey guys,
I'm completely new to buggies. I have the TLR 22sct so figured it'd be best to look at getting a 22 buggy since some parts would be interchangeable. So I'm looking for a roller and I'm getting price ranges all over the place. What is a reasonable price to pick up a 2.0 roller for? also a 1.0 roller?
Is a 2.0 any better than a 1.0 with the 2.0 geometric upgrades?
sduffy77 is offline
Old 04-03-2014, 08:53 AM
  #7222
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Originally Posted by sduffy77
Hey guys,
2.0 is definitely better than the 1.0, I'd look to pick up one of those.
Frank Root is offline
Old 04-03-2014, 09:09 AM
  #7223
Davidka's Avatar
Trader Rating: 86 (100%+)
Hi guys,
I have a couple of 22 v1.0's. Would anybody be willing to list, by order of importance/effectiveness the main 2.0 updates to be made? ie. front spindles/blocks, rack, rear arms, etc..
Davidka is offline
Old 04-03-2014, 09:10 AM
  #7224
sduffy77's Avatar
I presumed that 2.0 was a better buggy but is there any differences between a 2.0 and a 1.0 w/ 2.0 geomotetric updated.
sduffy77 is offline
Old 04-03-2014, 09:14 AM
  #7225
Speed Freak RC's Avatar
Originally Posted by Davidka
Hi guys,
Just upgrade the suspension geometry parts if you don't want to buy new cars.
I wouldn't just change a few parts here or there.
Speed Freak RC is offline
Old 04-03-2014, 09:23 AM
  #7226
addelrio's Avatar
[X ringsUOTE=sduffy77;13154791]I presumed that 2.0 was a better buggy but is there any differences between a 2.0 and a 1.0 w/ 2.0 geomotetric updated.[/QUOTE]
No difference in the suspension geometry once you upgrade a 22 1 to a 22 2.0. The difference is in the 2.0 shock shafts hinge pins pistons X rings and other little things that make it a great car. If you hold the lower shock link the new shocks will compres down from their own weight they are that smoth. I thought that they would leak but not a drop.
addelrio is offline
Old 04-03-2014, 09:40 AM
  #7227
sduffy77's Avatar
No difference in the suspension geometry once you upgrade a 22 1 to a 22 2.0. The difference is in the 2.0 shock shafts hinge pins pistons X rings and other little things that make it a great car. If you hold the lower shock link the new shocks will compres down from their own weight they are that smoth. I thought that they would leak but not a drop.[/QUOTE]
good to know.
what difference does the new chassis make?
sduffy77 is offline
Old 04-03-2014, 09:41 AM
  #7228
TLRacing
Frank Root's Avatar
Shocks
Diff
Slipper
Battery Mount
Body
Wing
Hinge Pins
etc...
Old 04-03-2014, 10:10 AM
  #7229
sduffy77's Avatar
Shocks
Diff
Slipper
Battery Mount
Body
Wing
Hinge Pins
etc...
lol sorry Frank, I need to be more specific with my questions.
What I meant was can you tell a difference in drive-ability on the track between the 2.0 and the 1.0 w/ 2.0 geo upgrades.
sduffy77 is offline
Old 04-03-2014, 10:28 AM
  #7230
TLRacing
Frank Root's Avatar
If you buy the caster blocks, spindles, rear arms, rack, and springs, then not too much. You'll just have a little more shock maintenance, diff maintenance, and it won't be as easy to work on.
