TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread >
Like Tree1Likes
Old 03-05-2014, 01:51 PM
  #6781
Originally Posted by mo
So I decided to just release my mid motor brace for people to order 3D printed, instead of spending a lot of money on molding. The material held up very well over the weekend with a few people running them and no problems. It takes flex out of the chassis but doesn't make it completely rigid. You can order in in standard or polished plastic and in a variety of colors. The type of plastic and color effect the final price and shipping time. I have no control over price or shipping as I am just making my design public for you to order if interested.
http://www.sculpteo.com/en/s/xmox/
Mo, how do I order?
rippen is offline
Old 03-05-2014, 02:19 PM
  #6782
Carranza76's Avatar
Originally Posted by MasiisaM
Looks like the export department at HH jumped the gun. TLR231027 is posted quite a bit in the EU.
Time will tell.
Carranza76 is offline
  #6783
MasiisaM's Avatar
Originally Posted by rippen
Mo, how do I order?
It looks like all you do is click the link...click the pic and add to cart..
MasiisaM is offline
Old 03-05-2014, 02:22 PM
  #6784
JourneyMan's Avatar
Trader Rating: 91 (100%+)
Originally Posted by Frank Root
22 2.0 Spindles stock spindles (w/4mm trail) found here:
http://www.tlracing.com/Products/Def...odID=TLR234007
Thanks Frank, I appreciate your help. However I am looking for the PN# for the correct trailing spindles for this ride. Amain lists the 4mm trailing spindles that were for the 1.0 as a compatible fit for the 2.0, but I know that is wrong.
TLR334005 is the 2MM Aluminum for the 22 2.0
1) What is the part number for the 22 2.0, 4mm aluminum trailing spindles.
2) Is there a PN# for plastic 2mm or 4mm trailing spindles for the 22 2.0?
I am looking to gain more corner exit steering.
JourneyMan is offline
Old 03-05-2014, 02:30 PM
  #6785
OK, so on the 22 2.0, the stock spindles that come with the car are +4mm trailing. The only way to get anything different is by using those aluminum ones which give you only 2mm of trail.
hacker07 is offline
Old 03-05-2014, 02:42 PM
  #6786
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
1) We do not offer 4mm trailing spindles in aluminum for the 22 2.0.
2) Answered with my previous post. The stock 22 2.0 spindles are 4mm trailing and are included in TLR234007. We do not offer molded 2mm trailing spindles.
Frank Root is offline
Old 03-05-2014, 02:59 PM
  #6787
MasiisaM's Avatar
Originally Posted by Carranza76
Time will tell.
Well..not really though. 40 websites have the part listed with a TLR# part number and photos that were shot professionally. Being the sites are selling to the end users the photo had to come from the manufacture.
Not too sure about the RC industry, but in the powersport and marine industry most dealerships are connected to distributions realtime stock/new product/update information though a program called Light speed. It simply takes a click of a box to make information available to all dealers connected to that network.
Being that the websites are all overseas then I would have to say the export department jumped then gun on info. It certainly wasn't done in a form a press release, but something else.
In any event it's great to see and looking at the retail price overseas with VAT included. It "should" be quite a bit less expensive than Exotek rack. The straight conversion puts the TLR rack at $24.99. That is with VAT so it "should be less" but giving the $64.99 price point for the Exotek rack it would be short sided to charge just $24.99 or less. I wouldn’t be surprised to see the rack for $34.99 –$39.99 USD.
End of my rant…the work day has been extremely slow.
MasiisaM is offline
Old 03-05-2014, 03:00 PM
  #6788
Cancun Tom's Avatar
Smile On road tires recommendations?
We occasionally run our 2wd buggies on an outdoor concrete basketball court. My 22 2.0 will wear a set of front Pro Line Caliber M3 to slicks in just one session. What could I switch to that would wear well and give good grip fronts and rears?
Cancun Tom is offline
Old 03-05-2014, 03:14 PM
  #6789
Proline Dirt Hawgs are a good all terrain option
Rear: http://www3.towerhobbies.com/cgi-bin...&I=LXDU13&P=SM
Front: http://www3.towerhobbies.com/cgi-bin...&I=LXDU14&P=SM
kawi650 is offline
Old 03-05-2014, 03:15 PM
  #6790
Carranza76's Avatar
The exotek is all aluminum though. so a big price difference.
Old 03-05-2014, 03:35 PM
  #6791
MasiisaM's Avatar
That’s true, but having a strategic price point is more important. While a few have (marketshare to how many 22's are in the market) purchased the all aluminum Exotech rack there is no scale behind it due to price point. Right now they are the only one in town doing a turn key kit. I think most consumers will be ok paying 35 bucks for a turn key kit made by TLR. Yea it has plastic parts, but its also 30 bucks less. That’s close to what you would have to pay for the plastic K mod but this would be turn key.
Advantage to both consumers and TLR.
MasiisaM is offline
Old 03-05-2014, 03:40 PM
  #6792
mo
mo's Avatar
Mo, how do I order?
Just click the link and you can change the color and material if you want and add to cart.
mo is offline
Old 03-05-2014, 07:49 PM
  #6793
Durocken's Avatar
Originally Posted by Oasis
Decreasing caster will generally add some turn..but you will lose some on power steering and straight line stability. .given your track discription this would help on tight off power corners.
Are you going to change the caster blocks so the overall caster isn't affected?
If you don't, you'll be changing two things: kick angle and caster.
I've found less kick to make the fore-aft weight transfer to happen quicker, sometimes too abruptly.
When reducing Caster, you'll generally have a little more turn in and exit steering, but less of a mid corner rotation.
Thanks guys I was just rebuilding my buggy for next weeks race and the 20* was sitting there looking at me lol. I wasn't gonna change the caster I was just gonna throw the 20* in and see what happens, just wanted to know if anyone tried it and how it affects the car. Thanks again for the info.
Durocken is offline
Old 03-05-2014, 09:48 PM
  #6794
Oasis's Avatar
Trader Rating: 38 (100%+)
No problem. .and Frank Root is the man when it comes to set ups..I've been racing for 30 years so I have learned a few things along the way..
Oasis is offline
Old 03-06-2014, 05:48 AM
  #6795
subaru_tech's Avatar
Trader Rating: 106 (100%+)
just ordered one of these up.nice option to have the color choices also.
just came back to losi products and picked up a 22 2.0 & 22-4
just could not get my serpent rm 2wd to stop pushing on power.
so when i got the 2.0 out on the track i was shocked to see how this buggy pushed on a medium bite dirt track.but know where near as bad as the serpent.
was ready to give up on 2wd buggy till my last effort i switched to mid motor on the 22.
what a world of difference running mid motor has made.now i have to try and loose some of the steering as it has to much.
on a plus the 22 mid motor has some of the same driving characteristics as the 22-4. makes it much easier to race back to back races with the 22 mm and 22-4.
just didnt understand the latest hype of mm till now.
subaru_tech is offline
