TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread
#6196
TLRacing
#6198
TLRacing
For those that can't make out the picture:
Front
Toe:0
Ride Height: 24mm
Camber: -1
Caster: 5deg
Kick: 25deg
Oil:35???
Piston: 4x55
Spring: LF Red
Pivot: Alum
Kick: Plastic
Limiters: 3mm
Shock Location: 2-Outside
Bump: STD
Camber Link: 2-A -- don't know if this is inside or outside??
Ball Stud spacers: 0 inner, 2mm outer??
Caster block: Middle
Rear
Toe: 3deg
Antisquat: 2deg
Low Roll
Ride Height: 24mm
Camber: -1
Rear hub: Middle
Hex: STD
Oil: 27.5
Piston: 4x55
Spring: LF Grey
Shock Limiters: 0-unscrew end 3 turns, O-ring on shaft to limit uptravel
Camber Link: 1-B ???
Ball Stud spacers: 0 inner, 1.5mm on hub
Shock Loc: 2-Inside
Weight: 7g on tranny
ESC on battery shelf
Dakotah needs to confirm the items in Bold.
Front
Toe:0
Ride Height: 24mm
Camber: -1
Caster: 5deg
Kick: 25deg
Oil:35???
Piston: 4x55
Spring: LF Red
Pivot: Alum
Kick: Plastic
Limiters: 3mm
Bump: STD
Rear
Toe: 3deg
Antisquat: 2deg
Low Roll
Ride Height: 24mm
Camber: -1
Rear hub: Middle
Hex: STD
Oil: 27.5
Piston: 4x55
Spring: LF Grey
Shock Loc: 2-Inside
Front Camber - 2A outside
Ball Stud Spacer - 0 inner, 2mm outer
Rear Camber 1-B
Thank you!!
#6199
What is the difference in feel from the 2 hole 1.6 to the 4 hole #55?
#6200
TLRacing
#6201
Dakotah, I see different set ups for the MM car with either 2 hole 1.6, 3 hole 1.4, or 4 hole #55's. Im just curious what different feel there is between two larger holes, compered to 4 smaller holes. I know the pack will be different, but when will one be better than the other?
#6206
MM will use a shorty, saddle, or square pack.
#6207
I did a track test awesome car make me look good
#6208
TLRacing
#6209
Reedy Champ interviews with 2wdMod.com
I know JP gets on and helps out in the forums. So do a lot of the TLR guys which I think makes this buggy thread really cool because of it. None of the other buggy threads has this kind of support! Wanna say thanks to the TLR team for their effort and support! Best buggy thread out there by far.
Have a quick read and get to know a little bit about the 2014 Reedy 2wd Open Champ - JP Richards! Awesome job buddy!
http://2wdmod.com/2014/02/03/racer-p...y-jp-richards/
