TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread >
Like Tree1Likes
Old 02-02-2014, 02:46 PM
  #6181
Does a standard 2s Lipo fit in the buggy on either rear motor or mid motor?
Tibbar110 is offline
Old 02-02-2014, 02:50 PM
  #6182
Trader Rating: 26 (96%+)
Rear motor it will work, mid motor it will not.
ntJeff is offline
Old 02-02-2014, 07:30 PM
  #6183
Trader Rating: 16 (100%+)
I think I read that when people are running mid motor, they usually run the aluminum camber rear camber block. Is this for weight or durability? Is there anything wrong with running the stock one?
Also, do people sometimes run 4wd tires on the front? I was thinking of trying some. Mostly on a higher grip track...using slicks.
Tommygun1 is offline
Old 02-02-2014, 07:32 PM
  #6184
Jokermayhem's Avatar
Default Help please....
Anybody have pics they can share of their speedcontroller mounted on the chassis behind the shorty lipo pack in rear motor? I wanna do this mod and wanna see it done first
Jokermayhem is offline
Old 02-03-2014, 12:31 AM
  #6185
mbtoolmaker35's Avatar
Trader Rating: 77 (100%+)
Not my picture but got this for a friend the other day!
mbtoolmaker35 is offline
Old 02-03-2014, 05:07 AM
  #6186
Rybeau40's Avatar
What are the differences between 4mm trailing and 2mm trailing spindle? What are advantages and disadvantages of each?
Rybeau40 is offline
Old 02-03-2014, 06:30 AM
  #6187
RC10B4_Mafco's Avatar
Trader Rating: 15 (100%+)
Originally Posted by RC10B4_Mafco
After running my rear motor 22 2.0 on a sugared track and noticing that in the corners it is very sketchy and doesn't feel fluid I'm going to convert to mid motor. Does anybody have a starting set-up using saddle packs, the esc mounted in the stock location on top of the battery brace and with no extra parts like the Rocket RC brass hinge pin blocks?
Anyone?
RC10B4_Mafco is offline
Old 02-03-2014, 06:53 AM
  #6188
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
the kit mid motor config?
Wildcat1971 is offline
Old 02-03-2014, 06:56 AM
  #6189
DavidAlford's Avatar
Trader Rating: 32 (100%+)
Is a low profile servo a must if you plan to put the ESC on the chassis? I don't have my car in front of me yet to look at.
DavidAlford is offline
Old 02-03-2014, 06:57 AM
  #6190
your going to need all of the space you can get. So, IMO yes, you need a shorty servo. I would use a small esc like the tekin or viper also and a small receiver.
Old 02-03-2014, 07:13 AM
  #6191
I wanna make as clean of a wiring job as I can. Everything just looks so cramped with the ESC towards the back.
Old 02-03-2014, 07:16 AM
  #6192
wait, are you asking about the esc on the chassis for RM or MM? For RM, you should be fine with a full servo ,with the esc in the rear and the receiver up front.
Old 02-03-2014, 08:27 AM
  #6193
kdeleon's Avatar
Anyone?
Did you try Dakotah's setup just recently posted? Might be the closest you get to out of the box configuration for MM.
http://www.rctech.net/forum/12967538-post6170.html
kdeleon is offline
Old 02-03-2014, 08:51 AM
  #6194
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Originally Posted by sickpuppy1
going from kit springs,just got LF spring kits and wondering which ones to try 1st. I'm on dirt rear motor, med-high grip....... looking for a bit more low speed steering as mine pushes a bit. Gotta put in my Casper thrust bearing too...
Red Front, White Rear. Be ready to try Yellow Rear
2mm will have a more direct steering feel.
Anyone?
Try Dakotah's setup, he runs no brass and his ESC on the shelf. It was posted on the previous page.
I run a full size servo. It has better durability and better performance.
Frank Root is offline
Old 02-03-2014, 10:40 AM
  #6195
skrichter's Avatar
Originally Posted by Dakotah Phend
Here is my setup from the Reedy Race.
For those that can't make out the picture:
Front
Toe:0
Ride Height: 24mm
Camber: -1
Caster: 5deg
Kick: 25deg
Oil:35???
Piston: 4x55
Spring: LF Red
Pivot: Alum
Kick: Plastic
Limiters: 3mm
Shock Location: 2-Outside
Bump: STD
Camber Link: 2-A -- don't know if this is inside or outside??
Ball Stud spacers: 0 inner, 2mm outer??
Caster block: Middle
Rear
Toe: 3deg
Antisquat: 2deg
Low Roll
Ride Height: 24mm
Camber: -1
Rear hub: Middle
Hex: STD
Oil: 27.5
Piston: 4x55
Spring: LF Grey
Shock Limiters: 0-unscrew end 3 turns, O-ring on shaft to limit uptravel
Camber Link: 1-B ???
Ball Stud spacers: 0 inner, 1.5mm on hub
Shock Loc: 2-Inside
Weight: 7g on tranny
ESC on battery shelf
Dakotah needs to confirm the items in Bold.
skrichter is offline
