TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread >
Like Tree1Likes
Old 01-31-2014, 09:24 AM
  #6151
Trader Rating: 25 (100%+)
Anyone have a good starting setup for a black dirt, hard packed bumpy, low traction/slick track with very small jumps but a few sharp 180's
toughtrax is offline
Old 01-31-2014, 09:26 AM
  #6152
Originally Posted by drgrcrp301
Which parts do you recommend ?
Casper's suggestion is a good one. Here are some words about it to give you an idea.
http://2wdmod.com/2014/01/11/a-littl...or-the-tlr-22/
sir_thomas is offline
Old 01-31-2014, 09:29 AM
  #6153
Originally Posted by ntJeff
Try running the ESC with no cap, and report back.
I'd do it, but I don't get to the track enough, and I hate wiring electronics in this buggy lol
I wouldn't try this myself. There is a reason almost every esc are designed with caps from the factory. I've had a bad cap before and the ESC was really hot.
Old 01-31-2014, 09:32 AM
  #6154
I tried the mid motor last night and I have the short pack starting set up on it and I don't have any extra alum parts that didn't come in the kit and it worked great with great surprise to me .. I'm glad I tried it and I'm looking forward to more track and tuning with it ,thnx TLR drivers for the hard work you put in on set ups .
blingy is offline
Old 01-31-2014, 10:02 AM
  #6155
Any chance we can get a peek at Dakotah's mid motor setup? I noticed he ran saddles and only the 7g weight, which seems to be much different than the newest MM setups posted!
Buckland is offline
Old 01-31-2014, 01:36 PM
  #6156
Rybeau40's Avatar
I'm having issues with the rear hubs. I broke two plastic ones the first week I had the kit completed using the center D hole. I bought the stronger aluminum ones and now instead of the hubs breaking, the ball studs both steel and titanium broke off in the holes making the $30 aluminum hubs worthless.
Many of the breaks are happening on normal landings on doubles at my local track. Possible design issue or is there a fix for this problem?
Rybeau40 is offline
Old 01-31-2014, 01:48 PM
  #6157
Carranza76's Avatar
Normal landings and breaking? Not sure I can concur that. I hit pretty good sometimes and have yet to break a hub or an arm or...... heck only a spindal once on the 22 2.0.
You drive at the same track as Wildcat?
Carranza76 is offline
Old 01-31-2014, 02:31 PM
  #6158
vito's Avatar
vito is offline
Old 01-31-2014, 02:54 PM
  #6159
wisconsinbasher's Avatar
Trader Rating: 31 (100%+)
Originally Posted by wisconsinbasher
can some point me in the right direction about pistons? what does what? im looking at getting a nice set of machined pistons but want to make sure i get whats right for my car but how do i know whats right for the car? right now i am runing the 1.6 and they seem to work well but i havent exsperaminted to much right now my car feels kind of soft going around the track but that cold be oil or spring changes any ways i could use some piston help thanks ps im running 17.5 got the car stripped of all aluminum and its as light as possible.
any one ?? if some one could give me the shock pistons for dummys run down that would be great
wisconsinbasher is offline
Old 01-31-2014, 03:10 PM
  #6160
DavidAlford's Avatar
Trader Rating: 32 (100%+)
It sounds like something is binding up when you land. Hold the car and compress the rear shocks all the way. Make sure something isn't hitting.
DavidAlford is offline
Old 01-31-2014, 03:30 PM
  #6161
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
awe, thats not funny, lol. Mine was because of the C hole. My daughter has used the A or D hole for months. She gangs the crap out of the pipes and has never broken a hub. IMO, the only issue I see is in the C hole. What that other guy is experiencing is poor driving. Now way to do that much damage otherwise.
Wildcat1971 is offline
Old 01-31-2014, 04:30 PM
  #6162
vito's Avatar
Originally Posted by vito
was fun I know I hade no body on lol
vito is offline
Old 01-31-2014, 05:46 PM
  #6163
ronP617's Avatar
check this link out bud.. this should help you out a little.
http://images.amainhobbies.com/image...Table_v1_0.pdf
I run these on my xb4 '14 and xb4 2wd.. they are great pistons, but to be quite honest the stock pistons on the 22 2.0 are just as awsome.. I really like the 2.0 suspension, I would just play with oils and springs before you change pistons.. The pros are running the stock pistons and they seem to be working really well so like the saying goes if its not broke dont fix it.. Sticking with the stock pistons is your best bet, IMO..
Hope that helps
ronP617 is offline
Old 01-31-2014, 07:58 PM
  #6164
Finally decided to go with saddles. Just ordered 2 from hobbyking. They're shipping from Hong Kong so now begins the terribly long wait. Plus they won't be back to work until Tuesday
Hinecken is offline
Old 02-01-2014, 05:59 PM
  #6165
RC10B4_Mafco's Avatar
Trader Rating: 15 (100%+)
After running my rear motor 22 2.0 on a sugared track and noticing that in the corners it is very sketchy and doesn't feel fluid I'm going to convert to mid motor. Does anybody have a starting set-up using saddle packs, the esc mounted in the stock location on top of the battery brace and with no extra parts like the Rocket RC brass hinge pin blocks?
RC10B4_Mafco is offline
