TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread
#6046
the guy in the orange is creepy, lol.
I am still running the FR rm setup also. I mainly play with oils and springs. Right now, I am hunting for less steering, lol. I am kinda thinking about lowing my voltage to the servo to slow it down. I am thinking .08 speed might be over kill. I dunno, I TQ'd last weekend and pulled off my best run, but followed it with counter steering corners and watching the rear chase the front.
#6048
#6049
I might play with it. Radio tuning is always nice because you can undo changes quickly during practice laps. I was running the BEC at 7+ volts, but it was very hard to drive the car. So I lowered to 6v. The car was very good most of the time. Like I said, I did TQ and pulled my best run on this layout. So I was not really looking to make big changes. I tried longer rear links before and the car was kinda hard to rotate, and with stiffer or softer rear springs, it either rolled too much or drove too flat. Same with the front springs. I might play with servo speed on the radio in practice next weekend, or better yet, smooth out my steering. lol
Anyway, I saw that phend was running a MM setup with very little added weight at the reedy. I hope his setup will be posted somewhere. Evan 2wd car looked great also.
#6050
Does anyone know what set up JP used?
#6051
#6052
What set up did you run Chuck? Did you use the waterfall?
#6053
#6054
I talked to JP in Ohio and he planned on using his setup from there at Reedy, at least to start. I'm sure he will confirm it in a few days after he comes down from his high
It's loosely based off Dustin's setup. He runs thinner oil in the rear and thicker in the front though. I wanna say it's 35 fr and 22.5 rear but I can't remember for sure.
#6055
Great thanks for the hints. Anything need to be done shock-wise between mid and rear motor? don't need to soften the shocks up a bit or anything in the rear?
I was thinking of running the TLR weights off the back of the tranny, but sounds like with a little adjustment to driving style, I can go without.
http://losiracing.blogspot.com/2013/...ing-chart.html
You'd want to go from 78/22 to something like 76/21 to keep a similar ratio. Benefit is having the motor further back in MM, or further forward in RM. I think is just help the weight balance. I run 19/76 in my MM car with a 6.5T.
#6056
in the book it 35 70 for a 17.5 I have a viper motor is 35 to tall to run its at 70 30 right now
#6058
When will the bell crank be available?
