TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread >
Like Tree1Likes
Old 01-24-2014, 03:27 PM
  #6001
Originally Posted by hockeyrules16
yes i was asking for diameter and length
diff bolt is 2-56 x .92in
http://www.amainhobbies.com/product_...ential-Screw-2
Buckland is offline
Old 01-24-2014, 04:06 PM
  #6002
Ok guys.
I'm literally just sitting down to start my build. Hope to have it done by midnight / 1AM. It's 7PM here now.
I need a piece of info first.
Can someone please verify what servo spacer I need for an Orion VDS 1409.
Please and thank you.
Jamie James is offline
Old 01-24-2014, 06:05 PM
  #6003
vito's Avatar
vito is offline
Old 01-24-2014, 07:34 PM
  #6004
Trader Rating: 42 (100%+)
Any concern with bending the chassis or breakage of the tower or something when not running the waterfall?
Nexus is offline
Old 01-24-2014, 08:14 PM
  #6005
wisconsinbasher's Avatar
Trader Rating: 31 (100%+)
This was asked about a month ago and I remember a lot of people replied to not having issues I have personally been running mine with out the brace for about a month and had zero issues and I did notice better rear end tracktion after moving the electronics and battery back
wisconsinbasher is offline
Old 01-24-2014, 08:50 PM
  #6006
Any body off pics of Evens car from the Reedy?
Dale.0 is offline
Old 01-24-2014, 08:51 PM
  #6007
vito's Avatar
iam geard 70 30 with a viper 17.5 at 45 timeing?
vito is offline
Old 01-24-2014, 09:17 PM
  #6008
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
its all about the temps vito. just check your temps often until you get it right. I try to stay below 150
Wildcat1971 is offline
Old 01-24-2014, 10:01 PM
  #6009
Hi guys
I have a question with step B-1M on page 40 in my manual.
In the pic it shows two parts ( both TLR232008) on either side of the smaller inner hub bearing. I did not have those in my kit.
Everything seems to fit and work ok. Just wondering if this is a running change or if it slipped past QC.
EDIT:NVM.....found them.
Old 01-24-2014, 11:07 PM
  #6010
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Haven't heard or seen it.
Frank Root is offline
Old 01-25-2014, 07:52 AM
  #6011
Just wanted to say how impressed I am with this kit. I'm 85% done and the build has been relatively painless. Basically just have to build the shocks and install the battery tray.
I'll be running a 13.5 motor on a small indoor carpet track. I had the 78t spur installed but when I looked at the gearing recommendations in the manual it says to use the 70t so I swapped it out.
Going to finish it up this aft while my daughter is on a play date.
Thanks Losi for a quality product.
Old 01-25-2014, 09:49 AM
  #6012
Assuming I'm a lazy guy and want to run my TLR 22 2.0 on carpet and track intermittently at different tracks, what are some of the big-hit items I'd need to do to give it as much traction as possible on medium-high bite clay track?
besides adding the weight kids to the back, what other tweaks should I be thinking of?
monsterfarm is offline
Old 01-25-2014, 09:56 AM
  #6013
I'd love to see this too
Old 01-25-2014, 11:53 AM
  #6014
Trader Rating: 166 (100%+)
I have a 22 2.0 fully loaded with every conceivable hop-up for sale in the for sale threads. Asking $325.00 for it. Way under what its worth.
jpcopeland1 is offline
Old 01-25-2014, 12:27 PM
  #6015
Rocket-RC anti-squat block, and maybe side pod weights from Rocket-RC. I saw Dustons car, and he was only running those after market parts. Most have pretty much ditched all of the weight. Exotek, or Kyosho bell cranks (modded) are a good thing to have as well. In stock I ditched all of the weight completely. Car was still very easy to drive with a ton of grip everywhere.
