TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread >
Like Tree1Likes
Old 01-11-2014, 06:33 AM
  #5596
Matt Trimmings's Avatar
Trader Rating: 170 (100%+)
Originally Posted by Otto.951
Does the aluminum 22 1.0 caster blocks fits on the 2.0?
No they are different geometry. They currently don't offer 2.0 caster blocks in aluminum. The plastic ones are plenty strong.
Matt Trimmings is offline
Old 01-11-2014, 06:34 AM
  #5597
Trader Rating: 30 (100%+)
Oh ok thanks.
Otto.951 is offline
Old 01-11-2014, 08:25 AM
  #5598
vito's Avatar
Originally Posted by racer1812
Can I guess you're sponsored by AKA? Their tire wipes are WAY over priced..IMO
Vito, motor spray on a rag will work just as well for tire and wheel prep.
@Vito, have you glued tires before? If not, have a local show you how to do it. Or watch some vids on Youtube. There's no easy way to explain it to you in text.
I use the thinnest glue I can find, but that's not likely the best for someone new to gluing tires. I t gives you zero "work time" to get the bead back in the rim.
(have you tried the receivers I sent you yet?)
not yet I got the last week thank you
I not good at guleing tires I shake bad and they don't hold well I have my friend do them.
my raido is dsm 1 and there dsm 2 wont work?
vito is offline
Old 01-11-2014, 08:55 AM
  #5599
Trader Rating: 25 (100%+)
I have the tlr 334014 rear hub carrier ,is there a left and right ?they are the 4 hole ones ,
Pete G is offline
Old 01-11-2014, 09:21 AM
  #5600
TLRacing
Frank Root's Avatar
Originally Posted by ntJeff
Frank, what does your car weight?
1625g
Originally Posted by vito
whats a good tire gule ?
Tried and true, TLR Standard
We actually tested of the different things people use to clean tires to see what worked and what didn't. Motor spray was actually the worst thing to used, over and over. No cleaning at all worked better. The winner was Windex, hands down. 2nd place was Simple Green. Best part is, they are both super easy to get and super cheap.
Not a left and right since they are different for mid or rear. Etching front for rear, etching back for mid.
Frank Root is offline
Old 01-11-2014, 09:27 AM
  #5601
vito's Avatar
I saw in rc car mag one time the don't touch them the tires. they guled the up right out of the bag
vito is offline
Old 01-11-2014, 09:35 AM
  #5602
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
I use simple green first to get the heavy stuff off, then use iso propyl alcohol before gluing. I also use the alcohol to clean the electronics and chassis before mounting.
Wildcat1971 is offline
Old 01-11-2014, 09:54 AM
  #5603
Suspended
Trader Rating: 11 (92%+)
Alcohol is what i use, great stuff!
theblitzkidd is offline
Old 01-11-2014, 12:17 PM
  #5604
vito's Avatar
just use some simple green and order some aka gule
vito is offline
Old 01-11-2014, 12:22 PM
  #5605
kdeleon's Avatar
Originally Posted by Frank Root
1625g
Wow, I must be doing something wrong as I just weighed mine and I'm at 1638. And I don't have any of the brass Rocket RC parts in my car. Here is a pic, maybe you guys can see a blatant issue. The car is pretty much stock 2.0. I do run the chassis protector on the bottom and my wires are stock length (so longer than they need to be). But I also run Lunsford titanium turnbuckles and shock mounts and a shorty battery. I don't have any brass weights in the car. No wonder I'm slower in stock racing.
Thanks for all your suggestions.
Attached Thumbnails TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread-img_0345.jpg
kdeleon is offline
Old 01-11-2014, 01:33 PM
  #5606
Durocken's Avatar
I've read most of this forum and couldnt find a setup for my conditions, I've looked at all the ones on TLR site and Petit. My track is extremely tight dusty clay very low temp and very low traction. Tires of choice are super soft suburbs. Other super soft tires do work as well. Track requires a lot of steering, on and off power. Any tips would be greatly appreciated! (I just switched to tlr 22 2.0 so I'm new to the car)
Durocken is offline
Old 01-11-2014, 01:52 PM
  #5607
Rafiki94's Avatar
What size is that battery?
Rafiki94 is offline
Old 01-11-2014, 03:07 PM
  #5608
I love the Losi standard glue. All I use.
I just lightly run some fine grit sandpaper around the mounting surface of the tire and rim, wipe down with a damp cloth and start gluing. Never had a tire come loose.
Attached Thumbnails TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread-image.jpg
Jamie James is offline
Old 01-11-2014, 03:14 PM
  #5609
When it gets slick, I pay close attention to my diff and slipper setting, if the track is real slick and jumps are small I will loosen my diff until it rotates a full turn when spun by hand, then loosen the slipper a good bit.
raise rear roll center (take away inner rear camber link washer) The high roll center will keep the rear end level throughout the turn, helping the onpower steering, but the camber rise will increase keeping the rear end planted.
Just a few ideas!
synap2012 is offline
Old 01-11-2014, 03:40 PM
  #5610
AndrewTom's Avatar
is that a long pack?. as i remember, Frank and most are running Shorty packs, which weigh significantly less then long packs.
but, then again, not all shorties are the same weight and/or weight savings.
AndrewTom is offline
