TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread >
Like Tree1Likes
Old 12-12-2013, 02:51 PM
  #4666
Trader Rating: 22 (100%+)
Originally Posted by Casper
To get full through on a 22 car you need to go above 100 on travel EPA. This is normal. This car has a lot of steering throw.
should I worry about having such a large amount of subtrim dialed in? It's been a really long time since I researched this, so I can't remember if subtrim affects overall steering throw.
Bob Barry is offline
Old 12-12-2013, 03:00 PM
  #4667
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
My subtrim stops at 100, so I would move the horn. I am also at like 50 left, but I full lock in both directions. But I use a mt4
Wildcat1971 is offline
Old 12-12-2013, 03:09 PM
  #4668
Trader Rating: 26 (96%+)
Broke a diff bolt, man that was weaker than I expected.
Antyone know if the AE bolt will work?
ntJeff is offline
Old 12-12-2013, 03:17 PM
  #4669
3D-Seth's Avatar
Trader Rating: 36 (100%+)
I generally try to move the arm if I'm over 50 subtrim. That shouldn't affect travel both ways though, should only affect 1 direction.
Seth
3D-Seth is offline
Old 12-12-2013, 03:21 PM
  #4670
Seth
Well I just double checked and you are right, I'm at 120 one direction and 108 the other. I'll see how it is at practice tomorrow and then if I need to, I'll take it apart on Saturday.
I guess my original question still wasn't answered though. Should I have to go through the process of lengthening the link off the servo like I did? I probably didn't notice it as much with the Futaba servo because of the extra throw.
Old 12-12-2013, 03:29 PM
  #4671
Yes. i had the same problem when i built my car and noticed the sub trim was way off, like 100 to the left i did the work to correct that and now i think i'm only 5 to the left it does make a difference trust me.
rracer is offline
Old 12-12-2013, 03:30 PM
  #4672
archerwin's Avatar
happened to me as well. they say the AE diff bolt + the AE nut should work.
Good thing my local LHS has a spare that I was able to use.
archerwin is offline
Old 12-12-2013, 03:39 PM
  #4673
Cool, thanks.
ntJeff is offline
Old 12-12-2013, 03:44 PM
  #4674
i use the AE bolt, nut and thrust washers. They seem to have better quality than TLR's.
nicmo is offline
Old 12-12-2013, 03:53 PM
  #4675
wisconsinbasher's Avatar
Trader Rating: 31 (100%+)
does any one know if you need the avid top shaft to run the avid slipper pads?
and is any one running the mip pucks system on there 2.0 and how do they like it thanks
wisconsinbasher is offline
Old 12-12-2013, 03:55 PM
  #4676
vito's Avatar
no it will bolt up to the stock shaft
vito is offline
Old 12-12-2013, 06:23 PM
  #4677
pig penn98's Avatar
hey i was just wondering how long it takes to build the losi 22 2.0 if i can buid the entire thing overnight
pig penn98 is offline
Old 12-12-2013, 06:49 PM
  #4678
It took me about 5 hours to build, not using power tools, and I made a lot of mistakes and had to backtrack.
About another hour or so in wiring everything up cleanly.
ntJeff is offline
Old 12-12-2013, 07:12 PM
  #4679
cantrell8's Avatar
You can if you've build a few kits, it's fairly basic and the plastic can be hard to screw into, black grease on the threads is a must. I would recommend opening all your hardware first and keep your calipers handy.
cantrell8 is offline
Old 12-12-2013, 07:14 PM
  #4680
vito's Avatar
is the new losi body got more room for a esc then a bulldog
vito is offline
