TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread >
Like Tree1Likes
Old 11-22-2013, 12:48 PM
  #4066
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
yeah, just dial in the brakes you need and no more. I think my trigger throw is 70/30. mean 70% it throttle and 30% is brake. And if you use max brake setting, its pretty easy to over brake with such a small throw. maybe other radios are different.
Wildcat1971 is offline
Old 11-22-2013, 02:52 PM
  #4067
Trader Rating: 126 (100%+)
Originally Posted by Frank Root
I run 62.5% in the Orion ESC and 75% in the radio.... (46.9% overall)
Frank do you use the same or more in say a 22T?
kwiksi is offline
Old 11-22-2013, 02:57 PM
  #4068
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
More in truck, 75% ESC, 75-80% radio. SCT is the most though, 100% ESC, and 65-70% radio usually. It all depends on track conditions/grip/etc. I adjust it quite a bit when running away from OCRC.
Frank Root is offline
Old 11-22-2013, 03:23 PM
  #4069
gogi108's Avatar
Interesting , I have always just used 100 esc and then tune the radio to stop lock up or where I feel comfortable . Might have to play with this some more
gogi108 is offline
Old 11-23-2013, 09:51 AM
  #4070
Trader Rating: 22 (100%+)
Did some testing last night with Mid Motor last night. It's really good but I'm not sure it's for me yet. I need to get lap times and see if it's faster or not.The two things that I changed that made a monster improvement were open cell rear foams and the Rocket-RC-Parts front toe block. It's made of brass so it adds roughly 30 grams right where you want it, down low and close to the axle.
The rest of the setup was Evans RCE setup. The only differences were I used the waterfall brace and the slider where he used no waterfall and bell crank.
I'm going to get some baseline lap times and then switch from 1.6's to 55's and see how they change.
Bob Barry is offline
Old 11-23-2013, 10:28 AM
  #4071
vito's Avatar
on the losi ti bolt kit the front end ones were on the money. the rear end was off a tad to short or long. sizes
vito is offline
Old 11-23-2013, 10:42 AM
  #4072
Trader Rating: 223 (100%+)
Ok Guys I was going thru all my spare springs and parts from my 1.0
Are these white springs on the right LF ?
The ones on the left are the stock yellow 22 2.0 LF springs
Manatarms25 is offline
Old 11-23-2013, 10:45 AM
  #4073
Matt Trimmings's Avatar
Trader Rating: 171 (100%+)
They look like the standard springs. The LF springs dont have a shiny black finish to them, they are more of a flat color.
Matt Trimmings is offline
Old 11-23-2013, 10:50 AM
  #4074
Thanks Matt, Bummer I have like 4 sets of those Figures
Old 11-23-2013, 10:58 AM
  #4075
Trader Rating: 16 (100%+)
Agreed.
The white LF spring would also have more coils than the yellow LF spring. It doesn't look like that is the case in your pic. http://losiracing.blogspot.com/2013/...ing-chart.html
Tommygun1 is offline
Old 11-23-2013, 10:59 AM
  #4076
Trader Rating: 36 (100%+)
I believe the LF spring chart has the amount of coils for each spring as well as its rating...might wanna look into that to confirm...
MikeGonzo is offline
Old 11-23-2013, 02:55 PM
  #4077
AndrewTom's Avatar
also, the standard springs have the color code marking at the top and/or bottom of the spring.
the LF springs have one marking 2 or 3 coils down from one end of the spring.
AndrewTom is offline
Old 11-23-2013, 04:36 PM
  #4078
vito's Avatar
what sims fro a low pro savox?
vito is offline
Old 11-23-2013, 05:29 PM
  #4079
addelrio's Avatar
Talking
Vito providing random humor on the TLR 22 2.0.
addelrio is offline
Old 11-23-2013, 05:50 PM
  #4080
Dirtryder219's Avatar
Trader Rating: 59 (100%+)
Vito, my oldest son runs a low pro savox with 2.5mm worth of shims.
Dirtryder219 is offline
