TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread >
Like Tree1Likes
Old 11-12-2013, 03:39 PM
  #3766
Jason Turner's Avatar
Trader Rating: 67 (100%+)
My take on the custom Mid Motor shorty setups not quite together yet, but it seems like everything should work okay
Jason Turner is offline
Old 11-12-2013, 03:58 PM
  #3767
Suspended
Yes, that's been done many times before.
BNaylor is offline
Old 11-12-2013, 04:44 PM
  #3768
Trader Rating: 22 (100%+)
I'm terrified that I'll bend my chassis without the waterfall brace.
Bob Barry is offline
Old 11-12-2013, 04:58 PM
  #3769
Rear motor battery strap rear chassis brace and no waterfall? Hadn't seen it yet sorry for re posting
Old 11-12-2013, 05:31 PM
  #3770
Suspended
No big deal, I know you've come over from the AE side. But the original 22 has been out about 3 years now, and just saying a lot of things have been tried before. Finding enough room for all the electronics has always been a struggle when running the car in mid motor configuration with the original car, along with guys seeking ways to increase rear traction. People quickly found out that removing or loosening the bottom screws on the waterfall allows the rear of the chassis to flex more, and I think I saw an article about modifying the rear motor chassis bulkhead to use as an ESC mount at least a year ago (maybe 2). It's all about finding what works for you, and now that the 2.0 has guys trying mid motor again these things are just popping up again. You might want to read through the original 22 discussion, and pick up some other ideas to try.
BNaylor is offline
Old 11-12-2013, 05:50 PM
  #3771
F1Yankee's Avatar
Originally Posted by Dale.0
Anyone have a body off pic of Evens MM 22 2.0 with the shorty?
i saw evans last month and he was running saddles
F1Yankee is offline
Old 11-12-2013, 05:51 PM
  #3772
vito's Avatar
save up to get a tekin rs gen 2 with a 8.5
vito is offline
Old 11-12-2013, 08:06 PM
  #3773
Trader Rating: 25 (100%+)
Hey guys I need some help. I just put a complete new diff (TLR232000) into my 22 converted to a 2.0 mid motor with new avid bearings but I have play left to right when I install my diff into the case. It's about 1-1.5mm when I push it in one direction, I tried to look for some shims to tighten it up but I've had no luck so I thought I would check to see if anyone has had this problem and how or what you used to tighten it up. Thank you in advance.
toughtrax is offline
Old 11-12-2013, 08:09 PM
  #3774
Originally Posted by Casper
Not sure how else to get that much weight on the car. How old is that setup?
http://www.petitrc.com/setup/losi/se..._FZRC20121103/
Just a few day back on this set up it looks like?
B rad919 is offline
Old 11-12-2013, 08:33 PM
  #3775
Evens latest set up on the TLR site says he ran a shorty with out the brace.
Dale.0 is offline
Old 11-13-2013, 07:40 AM
  #3776
Laurila's Avatar
Trader Rating: 21 (100%+)
Another ESC to think about is the SANWA Super vortex.. I just put that in my MM 2.0 with the 472 receiver... Hands down the smoothest esc I have run.. Will be interesting if anyone other than rcmart will sell them... Gettin rid of all my LRP stuff and switchin over.
Laurila is offline
Old 11-13-2013, 07:48 AM
  #3777
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
I assume your running it with an m12? I still want to know how much of the telemetry would work with the mt4.
Wildcat1971 is offline
Old 11-13-2013, 08:23 AM
  #3778
I use some 10x12 shims to avoid the play (don't get rid of it completely because of heat). There are some kits out there with 0.1, 0.2 and/or 0.3mm shims.
For example: http://www.amainhobbies.com/product_...mm-02mm-8-ZX-5
Gusi is offline
Old 11-13-2013, 08:41 AM
  #3779
vito's Avatar
I like the tekin I have a rs pro in a 44.2 with fantom 6.5
vito is offline
Old 11-13-2013, 08:53 AM
  #3780
Matt Trimmings's Avatar
Trader Rating: 171 (100%+)
This is for Wildcat....maiden voyage is this weekend.
Attached Thumbnails TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread-photo-1.jpg   TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread-photo-2.jpg
Matt Trimmings is offline
