TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread >
Like Tree1Likes
Old 08-08-2013, 02:55 AM
  #16
Joel Lagace's Avatar
Yahoooooooo
Now Frank. .. when is the TLR44 buggy coming??
Joel Lagace is offline
Old 08-08-2013, 03:05 AM
  #17
KalEl63's Avatar
Frank I am guessing that the Aluminum Mid Motor Rear Camber Block (TLR2061) will still fit?
secondly did the motor location in mid mount change and when I say that did it move backward at all or stay in the same position?
KalEl63 is offline
Old 08-08-2013, 03:39 AM
  #18
tony montana's Avatar
Trader Rating: 76 (100%+)
Any idea on what the street price will be and when can I buy it lol
tony montana is offline
Old 08-08-2013, 03:44 AM
  #19
mbtoolmaker35's Avatar
Trader Rating: 77 (100%+)
Thumbs up
Check the tlr link its 350.00 frank posted link
mbtoolmaker35 is offline
Old 08-08-2013, 03:47 AM
  #20
Thanks. To early in the morning still. Must have missed it
Old 08-08-2013, 04:12 AM
  #21
Trader Rating: 17 (100%+)
Definitely excited for the new buggy Frank! Looks good!
RodimusPrime49 is offline
Old 08-08-2013, 04:26 AM
  #22
what is the "Adjustable CVA Offset" ?
Are the new outdrives better? Never had problems with mine.
Hope the shock shafts are better than the golden bad joke ones.
Hope the body gives a bit more clearance now. Wonder how the cap forward body will look like.
I hope the new front will give more steering, the ackerman plate at least, nive to have this option without buying complete new racks from exotek now
And a not bent chassis in all kits .. that would be great too
takymo is offline
Old 08-08-2013, 04:31 AM
  #23
Awesome news Frank. Same rims?
Dave H is offline
Old 08-08-2013, 04:44 AM
  #24
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Originally Posted by Joel Lagace
Yahoooooooo
I can't give an info to this question.
Yes, the Alum Mid Motor Rear Camber Block still fits great. The mid-motor transmission did not change, so the motor is still in the same location.
$349.99 on TLRacing.com and HorizonHobby.com (when it loads on HH.com today)
I miss a lot this early too..
Frank Root is offline
Old 08-08-2013, 04:51 AM
  #25
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
Thanks frank.....can't wait....I'll order one up once mt Lhs opens up
Matt M. is offline
Old 08-08-2013, 04:56 AM
  #26
TLRacing
Frank Root's Avatar
Thanks Lyndon!
1. Adjustable CVA Off-Set allow the CVA pivot position and Bone to be mounted 1mm further into the hub (away from the centerline of the car), or with a 1mm shim, to be mounted in the original 22 location. When mounted into the hub, there is a little bit less bone support, and more weight can sit on the rear end during acceleration. When in the stock location, there is more bone support, and the rear end will feel more supported and slightly more up in the travel. This is also affected by driving style. I run the axle into the hub, it really fits the way I drive.
2. New outdrives aren't all new, just have an extra machining process that helps the diff feel smoother and less "wavey".
3. The shock shafts and hinge pins are all coated with Ti-Carbonitride now which has a grey-steely look. I have been running a set on my car for 5-6 months now and if I gave you a new set and the set off my car, you couldn't tell which each was, they are great.
4. The new body gives a bunch more clearance for saddle packs, and bullet connectors in the mid motor configuration, and extra clearance for the rear body clips.
5. A cab forward body image can be found here: https://www.facebook.com/photo.php?f...type=1&theater
6. The steering and balance of the car is great
7. I never came across any bent chassis, don't expect to now
Yup, except you now get one set of white and one set of yellow in the kit. Gotta keep it fair for all the guys
Old 08-08-2013, 04:57 AM
  #27
TLRacing
Frank Root's Avatar
Thanks Matt, it's going to be awesome!
On another note, would you mind making this the "Official" 22 2.0 thread?
Old 08-08-2013, 05:02 AM
  #28
Captcha's Avatar
OH JUST TAKE ALL MY MONEY!!!
not ordering another 1.0 kit now.
Captcha is offline
Old 08-08-2013, 05:04 AM
  #29
Captcha's Avatar
Also incase you guys don't know, frank root already has a setup sheet out for the 22 2.0
Captcha is offline
Old 08-08-2013, 05:11 AM
  #30
Captcha's Avatar
Question for frank: Will my rrear aluminum camber block, rear aluminum toe plates, front aluminum camber block, aluminum pivot, and brass kickup work on the 2.0 off of the 1.0?
Captcha is offline
