TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread >
Like Tree1Likes
Old 10-03-2013, 11:34 AM
  #2266
Trader Rating: 22 (100%+)
Originally Posted by vito
do a 17.5 don't rev that high that need a tall gear?
Hey Vito,
17.5 motors don't generate as much RPM as modified motors, so yes, you are correct.
The way you get your speed with a 17.5 is by putting a big pinion on there. You must be careful though because with any motor, speed = heat. That is even more true in 17.5. If you want to go fast, your motor will run hot. Keep the temps under 150 and you should be fine. I would shoot for 130's to be safe.
One other thing is that you really should get guys at the track to help you with your gearing. We can only give general suggestions because we aren't able to see things like jumps right after a turn, sweeping turns vs 180's, etc.
Bob Barry is offline
Old 10-03-2013, 11:38 AM
  #2267
Originally Posted by hacker07
I have tried many of them out there. I have gone to Sticky Kicks nowadays as they have many different kinds that work everywhere. It also smells good and doesn't make my throat hurt at the end of the night. Blue has been my favorite so far although the new red is pretty darn good too, lol.
Interesting. I might have to try it. I know that I was using Trinity Yellow Dot at our track last winter and it was pretty good. Problem is that it was only really good at that track.
Old 10-03-2013, 11:43 AM
  #2268
In reference to the JC front axle conversion....
Last year I used a long button head screw and used it as a through bolt...then used a 3mm flanged locking nut to secure the wheel. I used a longer than needed screw and just cut the extra off with a dremel.
Worked great and never had to worry about my wheel falling off again.
lovell is offline
Old 10-03-2013, 11:53 AM
  #2269
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
I have never lost a 22 front wheel. Is this an issue people have? I did break an axle once, but that was the only issue with it.
Wildcat1971 is offline
Old 10-03-2013, 12:10 PM
  #2270
F1Yankee's Avatar
lots of the 22 drivers i've seen, including myself, have lost a front wheel. blue threadlock makes sure that only happens once.
i can't say for certain it's always the same wheel. either way, threadlock is a much better option than left and right-handed hardware.
http://www.youtube.com/watch?v=PeIqXgaoSNM
F1Yankee is offline
Old 10-03-2013, 12:15 PM
  #2271
J@UNE's Avatar
I've lost the front left a couple of time as well. You rub the left side of the track and it loosen the bolt. The TLR alu serrated ones never let me down though.
J@UNE is offline
Old 10-03-2013, 12:42 PM
  #2272
yeah, I used blue thread lock on mine as well with the non serrated bolt and never had one come off.
Old 10-03-2013, 01:04 PM
  #2273
Orion_2kTC's Avatar
Anyone have an out of the box ready to run weight with all electronics and a shorty lipo?
Orion_2kTC is offline
Old 10-03-2013, 01:08 PM
  #2274
1585 grams
LPF servo
HW v2.1 esc
Reedy 17.5
Promatch 4000 65c shorty
Old 10-03-2013, 01:44 PM
  #2275
archerwin's Avatar
Originally Posted by Casper
The steering system for the 22-4 mimicks the XX4 and is completely different than anything that would work on the 2wd 22 platforms. Not saying you will never see a belcrank system for the 2wd 22 platforms but they will not share parts or look like the 22-4 setup.
Thanks Casper. This was the type of answer I was looking for.
archerwin is offline
Old 10-03-2013, 01:45 PM
  #2276
wild gopher's Avatar
Trader Rating: 39 (100%+)
1582 - weighed last night
Revtech Killshot 17.5
Tekin RS gen2
Full size Savox 1258
Revtech shorty
wild gopher is offline
Old 10-03-2013, 02:57 PM
  #2277
Let's see things I've tried to get car to not push and turn in.....
0 degree caster blocks,
Pink springs
M 3 compound fronts
Scrubs, tapers, slicks
Battery is all the way forward
2.5 rear toe in
Shortest camber link possible
Shawn Blackwell has been a big help in trying to get my car sorted out. It was set up like his yet his is dialed mine wants to plow hence why I'm changing the chassis, it's like something mechanically is right
Frank, you've driven my car in stock and it had that slight push still, now it just plows
I know it's a good car, I'm missing something
Jam-Air is offline
Old 10-03-2013, 03:30 PM
  #2278
Carranza76's Avatar
Pink springs
M 3 compound fronts
2.5 rear toe in
Could it just be your driving style?
Do you come hard in to the corners?
I was driving a 22 2.0 last Saturday owned by a TLR employee and it pushed for me real bad and come to find out he didnt have a lot of brakes in the remote and I love brakes so I had to ease up on the corneres with his car in my 1.0 i can come in hot and use my breaks prior to turning instead of having to go wide which was his line.
Just curious, I run the Exotek rack and not sure if that will cure your problem 100% but is a great up grade for my cars.
Carranza76 is offline
Old 10-03-2013, 04:12 PM
  #2279
goehm's Avatar
Trader Rating: 45 (100%+)
Pink springs
M 3 compound fronts
2.5 rear toe in
How's your diff? If it's super tight it'll push on power.
goehm is offline
Old 10-03-2013, 04:22 PM
  #2280
mbtoolmaker35's Avatar
Trader Rating: 77 (100%+)
+1 or maybe ride height off camber adjustments but if frank has driven your car I would wait for his help the MAN behind the machine!
mbtoolmaker35 is offline
