TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread >
Like Tree1Likes
Old 09-19-2013, 06:17 PM
  #1606
Originally Posted by nicholasxuu
you mean use the kyosho steering parts?
Are those the kyosho stand offs or did you make your own?
letrbuk is offline
Old 09-19-2013, 06:21 PM
  #1607
just 22's original stand off, the diameter is slightly smaller than 5mm (bearing has ID of 5mm ), I put some heat shrink tube there to make the difference.
I'm also curious if kyosho stand offs are long enough.
nicholasxuu is offline
Old 09-19-2013, 06:25 PM
  #1608
Yeah it would be nice to know the kyosho dimension.
letrbuk is offline
Old 09-19-2013, 06:28 PM
  #1609
Suspended
Originally Posted by vito
will a shorty pack fit in mid motor ?
Originally Posted by chuckinator
Yes it will. You will need a shorty servo to make your life easier.
Shorty pack fits fine with standard size servo in midmotor with room to spare for Rx.
Docrc is offline
Old 09-19-2013, 06:34 PM
  #1610
Matt Trimmings's Avatar
Trader Rating: 171 (100%+)
The Kyosho stand-offs are longer, you can cut them down to fit though and you wont have to use heat shrink to make up the difference in the diameter of the TLR posts.
Matt Trimmings is offline
Old 09-19-2013, 06:37 PM
  #1611
vito's Avatar
cant load the book up on the web site
vito is offline
Old 09-19-2013, 06:46 PM
  #1612
vito's Avatar
http://www.tlracing.com/ProdInfo/Fil...002_manual.pdf
vito is offline
Old 09-19-2013, 08:11 PM
  #1613
goehm's Avatar
Trader Rating: 45 (100%+)
http://lmgtfy.com/?q=my+computer+cannot+read+pdf+files
goehm is offline
Old 09-19-2013, 08:12 PM
  #1614
tfrahm's Avatar
I have a "parts" related question... When I got my 2.0, I also ordered some "spare" bearings for the inner rear hub because that was a weak point on the original 1.0 kits (at least it was on my 1.0)...
As in the past, I ordered LOSA6954 "5x10 HD Clutch Bearings (2)" 8B/8T"
Well -- I got quite a surprise. Instead of the usual HD bearings with the reddish/brown seals, I got the old "standard" bearings with blue seals...?
Was this a packaging error (I ordered two packages and both sets had blue seals), or has there been a change in the specs for these? Is there a better part number to order for these inner bearings..?
Thanks in advance...
tfrahm is offline
Old 09-19-2013, 08:22 PM
  #1615
Can't answer about the different seals....but you should check out AVID for bearings. I ran them in my 22 and in numerous b4's/t4's and have never had an issue.
Old 09-19-2013, 08:23 PM
  #1616
Thanks for the info
letrbuk is offline
Old 09-19-2013, 08:27 PM
  #1617
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
+1 I just order an avid tube(10) of the 5x10x4. A good portion of the bearing that get beat up are that size.
Wildcat1971 is offline
Old 09-19-2013, 08:33 PM
  #1618
Adonis_mp's Avatar
Trader Rating: 9 (91%+)
Can we get some part numbers, I would like to try it?
I still have the set (front/back) of yellow wheels that I'm willing to exchange or sell for $10 shiped.
Adonis_mp is offline
Old 09-19-2013, 08:45 PM
  #1619
chuckinator's Avatar
I was talking about with the speedo on the chassis. Should have been more specific on my part. If you mount the esc up top there is pointy of room. Things just get interesting when you try to put everything on the chassis.
chuckinator is offline
Old 09-19-2013, 09:24 PM
  #1620
mbtoolmaker35's Avatar
Trader Rating: 77 (100%+)
Part numbers
KYOLA256
KYOBRG002
KYOUM716
KYOUM718
Total at a main is around $32.00
mbtoolmaker35 is offline
