Like Tree52Likes
Old 12-31-2017, 08:48 PM   #11731
Cameron Kellogg's Avatar
Trader Rating: 45 (100%+)
Yes they will, I have a custom chassis (ed410 layout) that uses the Tekno shafts. They fit the D413 cups fine.
Tbuggy likes this.
Cameron Kellogg is offline   Reply With Quote
Old 12-31-2017, 09:32 PM   #11732
Sweet! Thank you for that!
Tbuggy is offline   Reply With Quote
Old 01-01-2018, 11:09 AM   #11733
czrlaker's Avatar
Trader Rating: 25 (100%+)
czrlaker is offline   Reply With Quote
Old 01-02-2018, 07:35 PM   #11734
Cuebulon's Avatar
does anyone else have excessive slop in the front end of their car? tried countless shimming methods to no success. any tips?
Cuebulon is offline   Reply With Quote
Old 01-02-2018, 09:27 PM   #11735
tc5 man's Avatar
Yup my does have a good bit got some runtime on it though doesn’t hurt to replace the arms they can get stretched out than they get quite sloppy .
Otherwise they are just made this way all around the front end and rear .
Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Hitec 7954sh, mamba monster 2200kv, airtronics MX-3 X. Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Mugen MBX6 ECO .
Hobby Hut offroad, Mushroom bowl offroad, Fun Center raceway.
GS HOBBY , Stormer Hobbies, Amain Hobbies, RRP Hobby .
Old 01-02-2018, 09:57 PM   #11736
The bushings in the spindles are usually the source of this. Exotek made bushings that removed the slop, but they are discontinued. The XB4 steering bushings work and remove the slop. You should be able to find the XB4 bushings on amain.
urnotevenwrg2 is offline   Reply With Quote
Old 01-03-2018, 12:26 AM   #11737
mustangkillaz's Avatar
Exotek bushes worked on early cars. The recent set I got did not fit. I think some of the orig slop has been removed. At the end of the day, there is some slop all over, some can be shimmed up, some can be tough. Still works well with the slop and might even be less edgy that way.
mustangkillaz is offline   Reply With Quote
Old 01-03-2018, 04:42 PM   #11738
Cuebulon's Avatar
are the bushings you speak of the long or short?
Old 01-07-2018, 01:45 PM   #11739
They aren't a perfect fit the other way around unfotunately. But I don't let little things hold me back so a tiny little bit of filing and they do fit the tekno outdrives. After measuring tekno's outdrives are about .5mm smaller in inside diameter. So thats why tekno shafts fit HB outdrives no problem but not visa versa.
Still made it work though!
Thanks!
---Tekno EB48.3---Tekno SCT410.3/EB48SL---TeknoEB410---
---TLR 22-4---Team Associated TC6.2---Schumacher M1---
Old 01-08-2018, 09:13 PM   #11740
Oh sorry, I am using the Tekno center drive shafts. Felt about the same slop as the HB ones. LOL.
Tbuggy likes this.
Old 01-11-2018, 06:20 PM   #11741
Trader Rating: 22 (100%+)
Darn, is there anywhere else that has the aluminum chassis. Woul like to pick one up due to running on carpet.
Agama A215T, Red R5R, Savox
Agama A8T E, tekin, Savox
Agama A8e Evo, Tekin, Savox
go4broke is offline   Reply With Quote
Old 01-25-2018, 10:10 PM   #11742
I blew a rear inner bearing (Left side). I will maintain these more often as it is a pain to remove them once this happens.
Does anyone use ball cups from another company? It appears that my camber goes out of whack when I hit stuff.
SouthFloridaApp is offline   Reply With Quote
Old 01-26-2018, 12:31 AM   #11743
tc5 man's Avatar
Are you using the stock Rear hubs yea depending on what bearings you are using they donít last long especially the outers. I stop using the Avid ones they donít last worth anything using JT ones now .
I been using the stock ball cups for a good while not sure what others work .
Old 01-26-2018, 06:45 PM   #11744
Does anyone know if the d216 rear hinge pins will fit a d413?
Or,does anyone have some hinge pins for d413 that they would be willing to part with?
afm223 is offline   Reply With Quote
Old 01-26-2018, 08:51 PM   #11745
MD
MD's Avatar
Trader Rating: 122 (100%+)
https://www.1001modelkits.com/rc-bod...SABEgKrC_D_BwE
I know nothing about this site.
MD is offline   Reply With Quote
