what servo works best
im looking to upgrade my steering servo on my losi 8ight t e. im going to run a cc bec to utilize high voltage. i was eying to different savox servos the 1267sg or the 1268sg. ones got more torque a bit slower then the other. im not sure looking at the numbers how much it matters torque versus speed. whats really necessary? the 1268 is .11 with 347 torque and the 1267 is .9 at 277 torque. any feedback would be great i don't know how to judge the differences.
HITEC
I use the savox 1267 in my 8ight Buggy on 6v bec and love it! It is fast and strong and have not had any problems with it.
Good point speed will get u in trouble sometimes. 7950 is the low voltage 7955 is the HIV version. Either way that is a pricey servo. Cheapest I'm seeing is around $125. I can't knock savox I'd say there'd comparable. Comes in a bit cheaper around $80.
Hitec 79XX servos rule!
7955 is perfect for nitro with 8.4v lipo.
7955 is perfect for 4x4 SCT or any 2 cells lipo class with a direct lipo setup.
But for E 1/8th, a faster model is better. I run the 7955 in my E buggy, but I might tap the balance plug to get 8.4 volts directly to it to speed it up some.
So the 7945, 7940 may be the better choice for E buggy. The 7945 would be my recommendation for 6.0v use.
I despise regulators.
Regulators don't hold a steady voltage under load as well as their specs say they're supposed to. And they tend to fail sending my nitrobuggy off the track at warp 4 until the conrod goes through the engines block.
Since Ebuggies generally don't have an engine to blow up, they just start glitching and end up in the creek/ river/ pond/ whale stomach instead. "CC 20a regulator" is fighting words.
If my ESC doesn't output 8.4 volts to my servo, because it's a pathetic ESC, then I try to get the servo 8.4v directly from the battery some how, or I run a faster servo that works ok at 6.0v like the 7945. Adding a failure prone regulator isn't needed.
I don't. E buggies are generally stuck with 6.0v output from the ESC. The 7955 is flawless at 8.4v, but a little slow at 6.0v.
