Whos the master of Tuning a nitro???
new to nitro...
but not to RC....
its in my 8th scale...
hyper .21 / os carb
but it will run fine in idol and putting but my full throttle right when i punch it, it sounds like its sucked dry and gulps and dies..haha if i explained it right...
its around 70-80 common down here...not much humudity...
any place to start with the screws...i was told to to 2 1/2 out on the top and 1 1/2 ont he bottom...this is where i am at...
any help would be great..thanks...
Mike
but not to RC....
hyper .21 / os carb
Mike
my guess would be the high end needle is too lean. whats the head temp? any trail of smoke?
Definetely too lean.Running it too lean will only make the engine starve of fuel when you gun it.
Sean
Sean
GReddy - Thats the most common symtom of a bad glow plug.
I highly suggest replacing your glow plug after an engine break-in.
Sean
Sean
the thing is that when i started having the problems i replaced the glow plug and its still happening
BUT when i put it on the glow igniter it glows bright red except the last coil on the outside
mayb theres something inside the engine? because after i get it started and i try to start it back up it feels as its flooded but its not
Temp the engine and see what it's at. If the temp is low try leaning it out some. It almost sounds as though it still to rich.
More technical info would help figure out your problem.
Hows the glow ignitor's batteries?
Sean
Sean
Greddy Id still say your engine fouled a plug. Its very common when you first start running a engine.
What glow plug are you using? What is the temp at when you have the problem? Will it idle without hitting the throttle? It can be to rich and shut off under heavy throttle. More info please.
Also, you mention it has a OS carb on it. They should be set at 3 1/4 out on the bottom and 2 1/2- 2 3/4 out on the top.
so even if it still lights up when put on the started, it could still be fouled somehow?
Its most likely your glow ignitor batteries man.
Sean
Sean
