xxx bk 1 steering
Old 06-08-2005, 12:13 AM
Default xxx bk 1 steering
Hi guys, I am new to the hobby and just purchased a new xxx KE. I am struggling to get front grip / steering. Have tried pink and red fronts, running red x-2000 on rear.Kit setup, hard packed short track in Australia.
Any help much appreciated ! thanx
jim beam is offline
Old 06-08-2005, 07:19 PM
Scottmisfits's Avatar
A faster servo and throttle control. These buggies aren't known for turning all that well. They tend to push through the corners. Try using the stock set up again. It's very neutral.
Scottmisfits is offline
Old 06-08-2005, 09:19 PM
losi jon's Avatar
go with losi 7202s in front..thats the silver compound...most times the reds will make you lose steering as they are too soft.
losi jon is offline
Old 06-09-2005, 12:45 AM
mafiaracers's Avatar
Trader Rating: 22 (100%+)
Make sure the battery is foward
Lengthen the rear camber link...like 1-a
Shorten the front link...like 3-a with no washers
softer front spring
stiffer rear spring
more pack in the rear....thicker oil
Just some suggestions....I'm running the same car and have more steering than I know what to do with so....maybe if you post your current setup it will give us a better idea of your situation and position....
mafiaracers is offline
Old 06-09-2005, 01:18 AM
Doughty's Avatar
of all the Losi ribs I find the 7206 (3-Rib BK Pre-Scrubbed) in red to give the most grip.
Doughty is offline
Old 06-09-2005, 09:56 PM
Default re bk 1 steering
hi and thanks to those who replied to my question. I will make some changes as described and see if i can make some headway in a B4 dominated class !
jim beam is offline
Old 06-09-2005, 11:18 PM
OldSkool's Avatar
What club/track you at in OZ?, Mr.Doughty is right about the 3 rib BKs.
At tracks like Wodonga, I have found X-2000's have a heap of rear grip, but a change to say big shots, help steering due to there rounder shape, and less grip.
The Kinwald worlds setup works very well here in OZ as well.
If you like I can PM some setup sheets for some of the OZ tracks
Hope this helps, Cheers
OldSkool is offline
Old 06-10-2005, 05:11 AM
Team Duratrax's Avatar
Hey Baden i wouldn't mind one of those setup sheets or a good setup for our track.Thanks
Sean
Team Duratrax is offline
