Old 06-05-2005, 12:06 AM   #1
Driver1's Avatar
Send a message via AIM to Driver1
Default Whos the master of Tuning a nitro???
new to nitro...
but not to RC....
its in my 8th scale...
hyper .21 / os carb
but it will run fine in idol and putting but my full throttle right when i punch it, it sounds like its sucked dry and gulps and dies..haha if i explained it right...
its around 70-80 common down here...not much humudity...
any place to start with the screws...i was told to to 2 1/2 out on the top and 1 1/2 ont he bottom...this is where i am at...
any help would be great..thanks...
Mike
Driver1 is offline   Reply With Quote
Old 06-05-2005, 12:20 AM   #2
dakrat's Avatar
my guess would be the high end needle is too lean. whats the head temp? any trail of smoke?
dakrat is offline   Reply With Quote
Old 06-05-2005, 04:03 AM   #3
Team Duratrax's Avatar
Send a message via MSN to Team Duratrax
Definetely too lean.Running it too lean will only make the engine starve of fuel when you gun it.
Sean
Team Duratrax is offline   Reply With Quote
Old 06-06-2005, 12:10 AM   #4
GReddy's Avatar
Send a message via AIM to GReddy
same for me but then when i rich it the engine turns off when i take the glow ingniter out you think the piston is worn? only half a gallon went in it though
and its a gx21
GReddy is offline   Reply With Quote
Old 06-06-2005, 02:46 AM   #5
GReddy - Thats the most common symtom of a bad glow plug.
I highly suggest replacing your glow plug after an engine break-in.
Sean
Old 06-06-2005, 05:17 PM   #6
GReddy's Avatar
the thing is that when i started having the problems i replaced the glow plug and its still happening
BUT when i put it on the glow igniter it glows bright red except the last coil on the outside
mayb theres something inside the engine? because after i get it started and i try to start it back up it feels as its flooded but its not
Old 06-06-2005, 05:42 PM   #7
GregH's Avatar
Send a message via AIM to GregH
Temp the engine and see what it's at. If the temp is low try leaning it out some. It almost sounds as though it still to rich.
More technical info would help figure out your problem.
GregH is offline   Reply With Quote
Old 06-06-2005, 05:45 PM   #8
GReddy's Avatar
how about what i said about the glow plug? and i just got a new pipe ofna 086
Old 06-07-2005, 03:41 AM   #9
Hows the glow ignitor's batteries?
Sean
Old 06-07-2005, 06:01 AM   #10
tony2's Avatar
richen the carb up until the engine bog and splatters, then slowly lean the main screw about 1/4 a turn keep leaning it out until the engine acelerates smoothly, the smoke trial i have found is a myth, as some oils dont produce much smoke when burnt.
Anthony Campbell
Ryper Hobbies l AKA | AE
tony2 is offline   Reply With Quote
Old 06-07-2005, 07:04 AM   #11
Greddy Id still say your engine fouled a plug. Its very common when you first start running a engine.
runnin rc10 is offline   Reply With Quote
Old 06-07-2005, 07:11 AM   #12
GregH's Avatar
What glow plug are you using? What is the temp at when you have the problem? Will it idle without hitting the throttle? It can be to rich and shut off under heavy throttle. More info please.
Also, you mention it has a OS carb on it. They should be set at 3 1/4 out on the bottom and 2 1/2- 2 3/4 out on the top.
Old 06-08-2005, 04:49 AM   #13
SMS
SMS's Avatar
Send a message via AIM to SMS Send a message via MSN to SMS Send a message via Yahoo to SMS
so even if it still lights up when put on the started, it could still be fouled somehow?
SMS is offline   Reply With Quote
Old 06-08-2005, 01:54 PM   #14
GReddy's Avatar
the 1st coil that you look at isnt lighted up
Old 06-09-2005, 07:22 AM   #15
Its most likely your glow ignitor batteries man.
Sean
nitro tuning? chiebap Nitro Off-Road 4 09-17-2007 12:15 PM
Need Help- Nitro Tuning acsubie Electric Off-Road 1 04-28-2007 01:09 PM
Tuning Guide for Nitro? K_King Electric Off-Road 6 02-16-2007 04:51 PM
Nitro engine tuning atr4tigers Nitro On-Road 2 06-24-2006 10:07 PM
Nitro Q's (no not motor tuning) Jammin'Trey Nitro On-Road 46 11-21-2005 10:16 PM
