-   Electric Off-Road (https://www.rctech.net/forum/electric-off-road-4/)
-   -   Can someone explain Droop and adjusting it? (https://www.rctech.net/forum/electric-off-road/740455-can-someone-explain-droop-adjusting.html)
cripplethreat 06-27-2013 07:54 AM
I don't understand droop or how to adjust it.. Youtube has no real videos to explain it.. I know it's probably a dumb question but I've gotta ask it.
ifuonlyknew 06-27-2013 08:06 AM
It is the amount of down travel the suspension has from ride height. In 1/10th scale it is usually adjusted by shims on the shock shaft that are inside the shock body, and underneath the piston. Some 1/10th scale cars, and almost all 1/8th scale cars use droop screws. They are screws positioned so that as you tighten them, the a-arm has less down travel.
Droop is a very effective adjustment for how much weight a car transfers.
Derry 06-27-2013 09:15 AM
Also for 10th scale you can change the shock end. Kyosho has short, medium and long.
porterdog 06-27-2013 04:28 PM
So 10th scale cars' downtravel limiter is generally the length of the shock?
ifuonlyknew 06-27-2013 07:42 PM
That is a fairly accurate statement. I think the Durango stuff has droop screws.
cripplethreat 06-27-2013 07:46 PM
I have durangos so where would droop screws be?
SMR 510RR 06-27-2013 07:48 PM
Lower suspension arms toward the inside.
cripplethreat 06-27-2013 07:49 PM
Thank you greatly. I love this board!
porterdog 06-28-2013 04:33 AM
Ditto CT.
XXXDad 06-28-2013 01:46 PM
http://www.competitionx.com/rc-racin...-tuning-droop/
