baja 1000 2wd slash >
baja 1000 2wd slash
baja 1000 2wd slash
Old 06-25-2013, 08:00 PM
DIRTBOY352's Avatar
Default baja 1000 2wd slash
well I got 2wd slash and wanted to turn it into a baja 1000 type of of truck. i started with a stock slash and got a couple parts on the way to my house. I want to go withe the paint below. i need to find a way to setup the spare tires. if any one has any suggestions on how to mount the spare tires that would be awesome. just started this and wanted to see how people liked my idea.
Attached Thumbnails baja 1000 2wd slash-slash-project-3.jpg   baja 1000 2wd slash-slash-project-2.jpg   baja 1000 2wd slash-slash-project.jpg   baja 1000 2wd slash-rpm.jpg   baja 1000 2wd slash-paint.jpg
DIRTBOY352 is offline
Old 06-25-2013, 08:25 PM
You should search rcshortcourse.com there has been more than than I can count of projects that has been completed.
Budman223 is offline
Old 06-26-2013, 09:06 PM
DIRTBOY352's Avatar
Exclamation !!!!!UPDATE UPDATE UPDATE!!!!!
got a present for those who are peeking in at this build. i have a wheely king axle and this truck WILL be a straight axle trophy truck. going to order rc4wd trailing arms( http://store.rc4wd.com/Hardcore-Scal...rm_p_1093.html ) maybe friday along with the m3 steel hiem joints for the rear end( http://store.rc4wd.com/Steely-M3-Rod...nt-_p_647.html) Im going on vacation in 2 weeks and i didnt want to cut into the chassis until i got back so i had something to play with down in san diego at a place called campland by the bay. but just an update for those who are peeking in, and leave a reply about any suggestion for this.
Attached Thumbnails baja 1000 2wd slash-dsc00435.jpg   baja 1000 2wd slash-dsc00436.jpg   baja 1000 2wd slash-dsc00437.jpg
Old 06-27-2013, 08:13 AM
DIRTBOY352's Avatar
Exclamation !FRONT SUSPENSION UPDATE!
Found two of the same shocks lying around and checked them out with my slash, and sure enough, they put the front pro trak arms at full extension. so now my front end has as much travel as i could get out of the front end without putting jato arms on. i posted pics below of the front suspension as it is now.
Attached Thumbnails baja 1000 2wd slash-dsc00443.jpg   baja 1000 2wd slash-dsc00444.jpg   baja 1000 2wd slash-dsc00445.jpg   baja 1000 2wd slash-dsc00446.jpg   baja 1000 2wd slash-dsc00447.jpg
Old 06-28-2013, 01:53 PM
DIRTBOY352's Avatar
Default eeee
come on guys tell me what you think so far.
Old 06-28-2013, 02:04 PM
RatsacK's Avatar
Trader Rating: 21 (100%+)
Picture quality is crap.
I'm more interested in how you plan to mount that rear diff and get power to it.
RatsacK is offline
Old 06-28-2013, 03:21 PM
rjohn929's Avatar
So far you have a 2wd Slash. I'm curious to see how it comes out with Wheely King axle in there. I have made a few live axle rigs and they don't handle all that great.
rjohn929 is offline
Old 06-28-2013, 03:27 PM
84 GT 5.0's Avatar
Trader Rating: 26 (96%+)
rear axle looks to narrow how are you gonna widen it to make track width equal? narrow offset front tires and wide rears? also interested on how your gonna get power to the rear axle
84 GT 5.0 is offline
Old 06-28-2013, 05:01 PM
DIRTBOY352's Avatar
To start off my i have an older camera so take it easy on my pics. Second im going to use these from strc ( http://www.teamstrc.com/index.php?ro...product_id=181 ) to widen the rear end. This will put the rear right next to the wheel wells. I plan on using the stock 2wd transmission and finding a way to lock one side so one side spins. Im going to put a castle sct combo running 3cell in it. Also got some stuff today from my local lhs and from the mail.
Old 06-28-2013, 05:10 PM
RatsacK's Avatar
Well, I wish you luck.
But, I don't like your chances either. Definitely will follow the thread though and see how it turns out!
RatsacK is offline
Old 06-28-2013, 08:16 PM
rjohn929's Avatar
Making it work is fairly easy. Lock the diff in the traxxas trans or run an axial trans and mount it on the chassis. Run the drive shaft from there. It's not like it's never been done before. It works and works fairly well but getting it to handle anywhere near as well as the independent suspension is going to be very difficult. Then again this might not be your goal, with that I say have fun and keep it slower then you want and take a bunch of video to make it look as real as possible.
You might want to check out Rccrawler.com and search for IFS rigs. A ton of information that you and a lot of other people who want to see this done can use. Granted most of them are 4x4 but the same principles apply.
rjohn929 is offline
Old 06-29-2013, 01:25 AM
DIRTBOY352's Avatar
Thumbs up start of the rear
So i decided to give myself the green light to cut for the rear instead of waiting for after my trip. So far i cut out for the drivetrain and mounted the transmission. I filled the diff with 2 part epoxy so it will be a locked differential so it will "drive" the truck. Also shaped out the rear for the truck.
Attached Thumbnails baja 1000 2wd slash-dsc00452.jpg   baja 1000 2wd slash-dsc00451.jpg   baja 1000 2wd slash-dsc00457.jpg   baja 1000 2wd slash-dsc00455.jpg
Old 06-29-2013, 01:41 AM
84 GT 5.0's Avatar
http://store.rc4wd.com/Hardcore-Slas...t-_p_1085.html
shoulda bought that^^
Old 06-29-2013, 01:50 AM
DIRTBOY352's Avatar
Originally Posted by 84 GT 5.0 View Post
that thing is overpriced imo.
Old 06-29-2013, 02:27 AM
DIRTBOY352's Avatar
Talking haha
thinking about getting a pair of these for the truck for fun http://www.bulls-balls.com/images/keyred.jpg
Copyright İ 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
