XRAY XB9E Official Thread - they did it :)
#1081
Building mine right now. All diffs have an insane amount of play in the gearboxes. Anyone else had this problem? User where you get 5 small
Shims, but nowhere in any literature I can find tells you to shim the diffs. Please advise. Duh. Google was my friend. Excellent build after that.
#1082
BTW, tried out the CSI V-Port red pistons on my Xray today. I was very impressed how soft the shocks felt, how they managed to work through every small bump and the car also squared up pretty well after landing the big jumps. Running the AE ones with 35wt in front and 30wt rear (Ultimate Racing oils). The track is dusty and rutty outdoor clay with quite open layout and some big jumps.
#1085
I don't know what you could put there to cover the hole. The stock spur runs flush with the bottom of the chassis. I just run it open. I ran it at Rev with no issues.
#1086
Love LRH. I haven't run mine on clay yet. Are you running the stock 16 deg caster blocks? My guess is, the 12 or 10 deg will work better at LRH.
#1090
Hey guys, are there any setups for tight indoor clay high bite tracks….Outdoors car works great….indoors…. it pushes on power very badly. Running 12 degree casters and even ran less around 11… changed roll center, running 3 degree rear toe, stock anti squat, nothing gives…it just refuses to rotate running 773 diffs. I had a tekno, and changed diffs to 10-7-5, and I could turn underneath anyone on the same track, this car's low speed steering is just not there. Any one running thicker diff fluids
#1091
I took mine out yesterday and had the same issue, there is a very sharp 180 degree turn and if you didn't break soon enough and hit the inside line, you pushed all the way to the edge of the turn and could possibly drift right into the back straight. Not good. I need to fix this before racing on Saturday. My first thought is to try a thinner front sway bar, or remove it all together like I did with the XB4, that car steers like slot car now and is so hooked up there it is insane.
You guys know how with some cars if you turn too sharp, the rear end will begin to rotate and come around on you, so you have to dial out some of the steering…..I need that problem .Lol I may just have to try the ackerman next…. or try the lightest front sway bar available. Removing it from the XB4 definitely helped it rotate and in the tight switchback and tight turn sections on the same track
#1092
Here's a thought…. has anyone ever switched hexes and put the wider ones in the rear and the standard ones in the front? Or tried standard all the way around?
#1093
Yep, I made the suggested changes, 5-7-2 diff, removed 1 degree of anti squat, shortened rear link, changed roll center on shock towers, and still….. it pushes on power in turns…..feels like something is just not right. I drove someones Tekno…it rotates more than you need, I was also helping a guy with a RTR Ofna buggy, and even that will rotate on itself if turned too sharp.
I don't have that problem at all on the outdoor track I run on. This thing corners like a monster in loose conditions.
Is there anything binding on the buggy? Bent inner hinge pins can cause it push like that.
#1094
Yeah it's on high bite clay, I will check for mechanical issues as well. I don't have that issue outdoors either.... But it is a little looser, pushes some but it rotates a little easier.
I am running 3 degree toe and -2 on camber
