XRAY XB9E Official Thread - they did it :) >
Like Tree1Likes
Old 08-28-2013, 10:45 AM
  #631
Pulse_'s Avatar
Originally Posted by gdw1963 View Post
I edited my personal details, never thought i would be posting this much on an English speaking forum As you can see i live in the neighborhood
We have two XB9E at the track ready to run, a third is coming and speculation for a fourth...
There are also allot of XB9's (2012/2013 versions), some use the ADS system from RB and some use traditional pistons setup. So it's only a matter of time to find a good setup....
Awesome! what tires do you run on astro? I use aka crossbrace in hard compound or schumacher mini spike in yellow. I know Dboots is making some too but I've no idea how they perform.
My girlfriend plans to change her buggy too next month, she's not sure about which one to get right now.
Pulse_ is offline
Old 08-28-2013, 11:02 AM
  #632
Suspended
Trader Rating: 6 (88%+)
Originally Posted by kineteks View Post
This was my issue Used my torque limiting electric screwdriver and didn't check that the screws were snug by hand. After cranking them down the wobble is pretty much gone...
The bearings still slide side to side, I need to add shims behind them, so there's no actual compression on the outer bearing race but it looks like I'm good to go!
thanks!
I would leave a little play. Just like we do with clutch bearings. Remember all that stuff gets hot. Heat makes things expand.
JaderL is offline
Old 08-28-2013, 11:55 AM
  #633
I mostly run Tourex X300 Syntrack, when the circuit is wet (damp) Tourex X300 Soft (some even super soft). There are some drivers trying Schumacher Mini Pin never seen Mini Spike at our track. Spirals seems to work also (have to try them myself some time). The reason for me using X300 Syntrack is that it is a cheap and very predictable tire combination whereas the Mini Pin's are unforgiving (grip, grip, grip...rolllll).
Does your girlfriend has something to say about the car she drives, lucky her. I'm wedded and my wive drives what i tell she can drive In her case she drive an SC10 4x4 FT, with a 4700kV at 35% or so :-) But she likes it and is just for giggles....
gdw1963 is offline
Old 08-28-2013, 12:06 PM
  #634
Pulse_'s Avatar
Of course she can, she buys them..
I'll try the tourex x300!
Pulse_ is offline
Old 08-28-2013, 12:36 PM
  #635
Tommy R's Avatar
Trader Rating: 21 (100%+)
Hey folks,
My Xray has developed a squeak somewhere in the driveline. I suspect it's a bearing, though I haven't determined that yet. Before I simply start tearing down and inspecting every single bearing and moving part in the entire car, I thought I'd ask if there is a common cause for this squeak? It's definitely in the drivetrain and not in the suspension.
If there isn't a common cause for this, I'll just start removing/cleaning bearings and replace as needed.
Thanks!
Tommy
Tommy R is offline
Old 08-28-2013, 09:37 PM
  #636
Suspended
Ready for The Clash next week in Mississippi!!
Attached Thumbnails XRAY XB9E Official Thread - they did it :)-20130828_130448.jpg
JaderL is offline
Old 08-29-2013, 02:11 AM
  #637
How did you setup your shocks? Stock or.....
gdw1963 is offline
Old 08-29-2013, 06:47 AM
  #638
Pulse_'s Avatar
stock for now because I still drive on clay tracks but I will run more and more astro tracks when it gets colder
@ JaderL: nice rides!
Pulse_ is offline
Old 08-30-2013, 07:53 AM
  #639
What pinions a are you guys running?
Wanted to run 18-19 with a tekin 1700 but the 19T I have is to large to fit properly.
I have a 17T that fits but I'm not sure if a 18T pinion would fit.
Anyone fit a 18T on the stock spur?
Voltron989 is offline
Old 08-30-2013, 08:18 AM
  #640
Just figured out the Internal gear ratio is 3.33:1 instead of the 4.3:1 I'm use to on my other buggys so I don't need such a large pinion lol
Old 08-30-2013, 09:03 AM
  #641
I have only testfitted a 18T pinion, and it seems to fit just. I'm currently running 16T with 1900kV and if my skills improve i go up to 17T (although thats really fast :-))
gdw1963 is offline
Old 08-30-2013, 09:42 AM
  #642
18 is the largest I have and fits fine. I was not sure a 19 would so thanks for confirming it for me
TXSlasher is offline
Old 08-30-2013, 10:04 AM
  #643
Yea 19T tekno pinion on the stock metal spur(not sure if going composite makes difference)
It would fit but no room at all to mesh. Good to know 18T can be squeezed in.
Going to try out 16 or a 17 pinion for the 1700. I mostly run indoor tracks so I don't need to gear to tall.
Old 08-30-2013, 12:14 PM
  #644
Nice! Good luck brother
Old 08-30-2013, 01:30 PM
  #645
Suspended
thanks guys.
17-19 pinion?? holy sh*tballs. im running a 14t and its plentttyyyyyy of power
JaderL is offline
