XRAY XB9E Official Thread - they did it :)
#586
I plan on getting one of these soon. Still up in the air between this and a EB48.2 since I already have a sct410
#588
Hi guys (and girls?),
today, my order from the US arrived (only took 4 weeks
), and I'm proud to present:
This is the FTW Night Fox for XB9'12 (part number FTW00033).
It's a tight fit, but a fit! Just need some washers to raise the front body post. As you can see, even the battery plugs fit.
IMHO the Night fox is much more beatiful than the Jconcepts
Greetings
Sven
Greetings
Sven
#589
I placed skid plates and I guess it protects the chassis right?
#590
MBX 7,EB48.2,Losi 3.0, 811e V2, MP9 and Ofcourse the XB9.
Each car will drive better then most of our skill levels will allow so there's really no wrong choice for most of us.
One thing I really like about the xray that kind of sealed the deal was the drivetrain being built with Hudy spring steel. Replacing worn drivetrain parts becomes expensive so getting the most out of each part becomes kind of important to me atleast.
I like the EB48 but honestly can't stand the owners of them. Say one negative thing about a EB48 and see what happens
#591
#592
#593
#594
Thanks man.
I took the springs out and compressed them by hand and it seemed to do the trick.
Ill try out the front xray blue springs
I have another question.
Manual isn't very clear on this.On the shock caps 2 inserts get pressed into the hole. One side goes a plastic insert and the other is a metal insert along with a plastic washer. Which side should be closest to the shock tower? Lol I tried to look closely at the pictures but I can't tell which is which
And are u using the stock downstop settings?
Thanks again for your help. Can't wait to try this buggy out. Mainly built it for indoor clay for the winter but I don't think I can wait that long so ill probably hit up some outdoor tracks.
http://bcrcs.org/setups//Xray/XB9E~8...~8-13-2013.jpg
#595
Kind of. The rear especially wears out a lot. IMHO they should just have made it a square through and through hole and have the diff case fit in that way so the plastic wears instead of the $$$ aluminum
. But I don't like skid plates can't get the ride height low and catches ruts a lot. I guess the grade of aluminum also matters a lot and the xray ebuggy wear is a lot less than my tekno truck wear.
#596
Ive had a number of xrays and Im an xray fan boy from way back because nothing beats them in quality, but I'm really surprised how close the EB48 is.
#597
Anyways one thing better in the tekno is shocks, rest everything the xray beats it (diff mesh, spur, drive shaft quality, diff cup quality, towers (CF tekno breaks a lot never broke an xray tower in 1/8, plastics, slop, servo saver list goes on). I am a kyosho fanboi but still love my xrays hands down the best compromise between quality/durability/speed/cost.
#598
Malin @ 2013 TheNeoRace.com
Bent
Bent
#600
