camber?
Old 05-29-2005, 12:58 PM
Default camber?
xxxnt pulls to the right. what adj. should i make? camber?? if so upper rod or lower. longer or shorter? thanx
peahbeez is offline
Old 05-29-2005, 02:44 PM
Trader Rating: 28 (100%+)
Try your steering trim on the radio. Just drive the truck away from you and adjust it to the left until the truck goes straight.
jbrow1 is offline
Old 06-02-2005, 02:29 PM
nwilcox88's Avatar
Check Toe links as well.
nwilcox88 is offline
Old 06-02-2005, 02:44 PM
what do u mean by toe links??
peahbeez is offline
Old 06-02-2005, 03:26 PM
nwilcox88's Avatar
the links going from the steering arms (servo) to the steering blocks.
