Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread >
Like Tree23Likes
    Hide Wikipost
Old 01-24-2018, 07:02 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
Last edit by: alex4r
Kyosho ZX6.6 New Parts (* = required to update ZX6 to ZX6.6 platform)
LA359B - Center Mount Set (ZX6.6)*
LA375 - Center Diff. Gear Set(ZX6.6)*
LA375-01 - Center Diff. Gear Case Set(ZX6.6)
LA375-78 - Spur Gear(48P-78T/ZX6.6)
LA376 - Center Drive Shaft (71.5/ZX6.6)*
LA377 - Center Drive Shaft (79.5/ZX6.6)* (x2)
LA378 - Center Drive Shaft (88/ZX6.6)*
LA379 - Joint Cup Cover (ZX6/ZX6.6)*
LAW54B-01 - HD Chassis*
LA355B - Side guard set*
UM713B - Rear Arms (from RB6)*
UM561 - Outer rear hinge pins*
LA236-12B - 1.2mm Front sway bar*
LA351B 4-hole front shock tower*
Options
VVC Blades TFW126
Spare Blades TFW001-01
Manuals
Lazer ZX6.6
Lazer ZX6
After Market Bodies
JConcepts Silencer
Weight Reduction options for 13.5 Class
Chassis:
UMW711B - Carbon composite rear arms
LAW60 - Carbon composite front upper bulkhead
LAW61 - Carbon composite rear upper bulkhead
LAW52 - Carbon composite front chassis brace
LAW53 - Carbon composite rear chassis brace
LA209HB - Carbon composite gear boxes (pinion bearing retainer & upper gearbox half only, lower half not compatible/saves 4.6g total)
Driveline:
LA211B - Plastic drive cups for center drive shafts coming out of front & rear gear boxes (requires drilling two holes for set screws to secure LA379)
TFW001 - Aluminum blade style outdrives (for ball diff/requires TF013)
LA202 - Aluminum pinion shafts (for ball diff)
TFW126 - VVC outdrives (for gear diff - front/rear/center)
TFW008 - VVC cross pins (for gear diff - front/rear/center)
Misc:
LAB06LW - LW Blade body
SK0402 - Ti screw set (Available at Lunsfordracing.com)
PTK-T-2111 - Ti screw set (cheaper, slightly less durable option)
LNS7765 - Ti ball studs
LNS2688 - Ti Turnbuckles
LNS36107 - Ti Turnbuckles (super duty)
W0201H - Hard anodized lower shock balls
1-N3024A-R - Aluminum M3x2.4 nuts (for shock standoffs)
1-N3033NA-R - Aluminum M3x3.3 locknuts
Print Wikipost
Old 11-21-2017, 12:04 PM
  #2251
alex4r's Avatar
Originally Posted by scoobyrs25 View Post
You can run the velvet aluminum outdrives with puck adapters on all three gear diffs and it is way lighter than the ball diffs and slipper.
Kyosho makes those out drives for the ball diffs too sans the velvet coating.
alex4r is offline
Old 11-30-2017, 08:49 AM
  #2252
Coach Townsend's Avatar
would that gearing be the same for 13.5
Coach Townsend is offline
Old 12-04-2017, 12:27 PM
  #2253
Drew Manzella's Avatar
Trader Rating: 33 (100%+)
Can anyone tell me the actual difference (in measurement numbers) between a B44.1 2.2 front wheel, a ZX6 2.2 front wheel and a TLR 22-4 2.2 front wheel?
Drew Manzella is offline
Old 12-04-2017, 01:42 PM
  #2254
Any news if any of the new prototype parts used in the recent world will be available for general public?
200sxr is offline
Old 12-05-2017, 02:17 PM
  #2255
What parts were used at the worlds??
Headling is offline
Old 12-05-2017, 05:17 PM
  #2256
I was hoping someone here would know more details! I was reading some of the online reports and they mentioned some prototype parts on Tebo's ZX6.6.
200sxr is offline
Old 12-05-2017, 06:00 PM
  #2257
Michael#81's Avatar
Trader Rating: 259 (100%+)
He has been running a -2mm from stock rear aluminum camber block and a wider D block. He was also using the 65.5mm rear Driveshafts from the RB6.6 and modding the rear hubs to reduce the track width.
On the front he has been running 74mm drive shafts and a 13* aluminum caster block. Not sure what the drive shaft or the caster blocks are from.
Michael#81 is offline
Old 12-06-2017, 02:04 PM
  #2258
Thanks.
200sxr is offline
Old 12-28-2017, 04:13 PM
  #2259
azeroth's Avatar
Trader Rating: 21 (100%+)
ok guys just picked a used zx6 really cheap what are the got to have to hop ups or spares these days running planning on running 13.5 I does appear to have the rb6 (gullwing rear arms) and not the flat rear arm I know it still has a ball dif up front (slips) so I have to go threw the thing complete recommendations?
azeroth is offline
Old 12-28-2017, 07:43 PM
  #2260
For 13.5, use the Kyosho aluminum outdrives on gear diffs or get the red aluminum parts for the ball diffs. The center diff accepts the aluminum outdrives as well. I put back on the lighter original ZX6 chassis. Lightest 4wd I own.
scoobyrs25 is offline
Old 01-03-2018, 02:50 AM
  #2261
Any ideas how tebo got the shocks on the front of the tower?? Some pics on his Facebook page
Zx5 parts of rear zx6 bulkhead on the front??
Headling is offline
Old 01-03-2018, 08:07 AM
  #2262
azeroth's Avatar
do you have a link to those parts? I am not having any luck finding them
azeroth is offline
Old 01-03-2018, 12:09 PM
  #2263
alex4r's Avatar
KYOTFW008 - Crosspins for center diff and/or front & rear diff
KYOTFW126 - VVC outdrives for center diff and/or front & rear diff
KYOTFW001 - Aluminum Outdrives for ball diff
KYOTF013 - Thrust rings for TFW001
Edit: KYOTFW124 - VVC cup for the center shafts coming out of the front and rear gear box. I haven't tried these personally, I would assume they are aluminum since they're velvet coated but not 100% sure. They only seem to be available through Kyosho America.
alex4r is offline
Old 01-03-2018, 02:26 PM
  #2264
azeroth's Avatar
thank you
azeroth is offline
Old 01-03-2018, 05:10 PM
  #2265
Super Moderator
Kraig's Avatar
Trader Rating: 73 (100%+)
The red aluminum outdrives might be a little to long so keep an eye on your dog bones. I say that based on the information that Jason Dias posted about getting his weight down on the RZ6 which he used those outdrives, click here to read it.
I used LAW46 on my wheeler when I had it with all of the other stock diff pieces. It probably isn't as light at the aluminum though.
Kraig is offline
