The New INTECH ER-12 Buggy 1/10th 2wd Pro Kit
#47
Yes except with 100's of dollars worth of option hop up parts already included.
It is based on the DEX210, but there are many differences as I have both right here and have just compared them. Some of the parts are interchangeable, but many are not. But regardless, it should be a good buggy.
#48
The ER-12 uses 12mm rear hex wheels and 3/16 bearing front wheels like the AE B4.1 so any front wheel for Team Associated and any rear wheel for Kyosho, Losi, and AE will fit.
#49
#50
#51
Between this and the HobbyPro buggy, I'm not sure which one to get.
#52
I have been building mine all day and actually the buggy is much more different then I originally thought. The front end is the same geometry but with some differences like the steering arms can be set in 5 places (inline or trailing), but the rear end is completely different.
It is a whole new rear geometry. The CVD's are 72mm long - way longer then the DEX210. The rear hubs are non offset and can be moved forward or back 7mm rather then 4mm. The camber link location is totally different and the roll center is different. The rear susp blocks are wider. The rear chassis brace and body mount is different. The side chassis guards are way smaller. The chassis is different and about 4mm longer then the stock 210. The gear box is different.
They did not send me any extra toe/squat blocks, so I am not sure if it has the LRC or standard anti-squat blocks yet. The shocks are also 12.5mm big bores so durango size pistons should fit.
#53
No problem.
#54
How does the front steering rack and geometry look? One issue with the DEX210 out of the box is that it has a fair amount of bump steer. There are easy fixes for this, but I would be impressed if the ER-12 fixed this. I like how it comes with good materials all around - see my first post about this buggy.
It also appears to come with a gear cover that fits stock and mod, which is nice for a change. For some reason Durango and Team C did not design their gear covers to fit stock.
#55
#56
#57
It uses the same rear chassis brace for rear and mid motor, so all you need to do it flip the gearbox 180'.
It also has way more chassis flex like molded chassis' do.
#58
Any test results yet?
#60
I had to add 3mm shims under the carbon fiber ackerman plate and now the car has 0 bump steer. The camber and toe remains the same on up and down travel even if the wheels are at full lock or straight. The ball studs mount on the bottom of the ackerman plate, so the tie rods don't hit the top plate on up travel.
The chassis flexes like a plastic molded chassis even though it is CNC Aluminum. So it should have a lot of traction and more forgiving in the bumps. The rear chassis brace allows a lot of flex also, so you don't have to modify or remove it to get more flex and rear traction. The CVD's are very long so they will never pop out.
It comes with a thick carbon fiber battery hold down too. Both of the rear suspension blocks are CNC aluminum. They are not the LRC, but option blocks could be made easily. It comes with 2 CNC toe blocks, one for MM and one for RM. The front anti-squat CNC block is a 0'. There will be a 1.5' and 3' CNC block available as an option part, or you can just add shims under the stock block to increase anti-squat. I put a 1mm washer so now it has 1.5' anti and 3' toe. The toe is also adjustable at the hubs and so is caster.
Can't wait to get it to the track Saturday.
