speed passion help
Old 05-04-2013, 06:09 PM
Default speed passion help
I am currently running the speed passion reventon pro and a speed passion 13.5 motor in a shumacher cougar svr. dose anyone have any advise on what the best mode and the best timing to be running to get the most power out of this setup. thanks
dro1313 is offline
Old 05-04-2013, 07:55 PM
Captcha's Avatar
Go post in the speed passion thread you will get the answers you are looking for their.
Captcha is offline
Old 05-04-2013, 08:45 PM
Which 13.5? I run the MMM at 20 degrees with 30/76 gearing in blinky mode.
cr133r is offline
Old 05-04-2013, 10:35 PM
MOmo's Avatar
Everything you need to know is in this thread. Start at the back and work to the front or even search for the motor (13.5) and see what others posted.
http://www.rctech.net/forum/electric...on-thread.html
Chances are no one will have an exact fit for you. Start with the default and adjust up or down as needed. You really should search better, the speedpassion thread is pretty big and discusses older and current models.
Also check the team site for setting too.
Momo
MOmo is offline
