Duratrax 835E 1/8th RTR Buggy
#1141
mines on the bench for a rear diff re-build. I had no issues w arms or tires. Plastics are too soft. My suns and planetaries are fine . The diff case is shot
#1142
Got a couple sets of the Ofna / HoBao gears. You can tell that they do not come from the same mold / press. The holes in the back are shaped differently and they look more precise. The steel is a lighter color as well.
I don't care for these thin .001 shims in the diff, riding against the rubber seals that don't allow them to sit flush against the housing. That seems to be an issue. I've rebuilt two diffs and both times, those shims were bent into crescents. I figure that's what is allowing the slop in the mesh and the Duratrax gears just can't handle that.
By comparison, my Vorza diffs have no shims on the sun gears at all. No bendy shim, no mesh slippage. Too bad they won't fit the 835. Looks like these new gears do the trick anyway, from what I've read here.
#1143
Is anyone still running one of these? I am seeing one on FB-marketplace for a very attactive price. But it seems that the parts for this car and similar cars are hard to find. If I can't get parts then no price is cheap enough.
#1144
I sold mine years ago and just got back into RC in the last year or so. I went with Arrma this time and love them.
#1146
I would get something more up to date with better support....
#1148
If I buy it, it would be a secondary vehicle for me. My primary vehicle is required to have strong parts support. I may be trading my imitation Slash for an RC8.2e roller so this duratrax may have to sit.
#1149
hey guys I'm trying to get the 835e back up and running but both of my trakpower 5600 4 cell batteries are dead. Both are bulging neither are worth trying to save, any thoughts on a replacement for what's out there? Currently running a shorty 2 s4000 on a rock crawler so I've been out of the speed market for a bit now...
#1150
I use Venom 4s 50c 5000s....Been good enough for me....
#1151
I run cheap batteries and have been pretty satisfied with Zeee packs, so far. But the ones I have are still pretty new. After running two 2S packs in series in my 1/8 Ebuggy, they came out (after hitting the LVC limit) barely warm, within a couple of hundreths of a vole between cells and measured 2,2,2 and 3 ohms. Based on previous tests, I think their Mah specs might be a bit inflated but if they hold up well, I can tolerate that little issue.
#1152
wondering if i should be lubricating the dog bone ends or gears? The buggy is still running like a beast, and I took delivery of a pile of replacement parts today. What type of general TLC do you guys go to this old dog? we have an sct10, and 2 crawlers... no way am i going to drive those if this thing poops out. About to embark on a steering drag link replacement...
#1153
#1154
Hi, RC newbie here. Just want to share that ye olde 835E has resurrected as a FS Racing Focus 6S. My order came with discontinued Arrma ESC and servo components which fried after a single run. Fortunately I was able to get a partial refund—which went into a new Hobbywing 150A ESC, and 20kg digital servo. Now the new-old beastie is back. Was worried about parts—so glad to find this thread so that I have more search options in the future if things starts breaking. Will share photos when I've passed forum probation.
#1155
Hobao diff gears
Stripped the center diff in my 835E on 5S 4 pole 2100 KV turnigy. Had really thick paste like center diff lube in it. Hobao 87002 diff gears worked with their supplied shims. Hobao 87006 center diff cups also worked great. The overall length is the same but as mentioned earlier, the cups are deeper. I used an 88 mm dog bone from the rear axle (replaced 86) up front and it fits with perfect end play. The rear will need a 98-100 not sure yet but I put a spacer in it for now.
