b44.2 AVID chassis.... worth it? >
Old 05-26-2013, 11:52 AM
  #16
policeman0077's Avatar
is it compatible with B44?
policeman0077 is offline
Old 05-26-2013, 01:24 PM
  #17
Suspended
Trader Rating: 23 (100%+)
Has anyone tried using the Avid chassis protecter? If so, is it holding up?
Team G Racing is offline
Old 05-26-2013, 01:29 PM
  #18
RC*PHREAK's Avatar
Trader Rating: 146 (100%+)
a buddy of mine has the avid chassis and put the avid protector on it. after one race night it still looks very good (on an abrasive outdoor track). he used to use associated's protectors and those don't even come close to comparing from what he said.
RC*PHREAK is offline
Old 05-26-2013, 01:31 PM
  #19
Suspended
Alright. The reason I ask if becasue I had a different brand chassis wrap, and after the first night it had already started to tear in areas and just got worst from there.
Old 05-26-2013, 01:33 PM
  #20
RC*PHREAK's Avatar
again, this is two quals, a main, and two batteries of practice. that's not a tear on the corner, just some dirt:
Old 05-26-2013, 02:14 PM
  #21
Suspended
Wow! Looks great! Alright I will give it a try
Old 05-26-2013, 05:53 PM
  #22
kdub's Avatar
You can put the chassis with +8 upgrade on a B44 or B44.1, all parts will bolt-on. You will have to figure out your own body, whether you want to trim and re-drill the rear post or get a longer B44.2 body.
The weight is 55g heavier than the carbon fiber chassis, but that is assuming no ballast weight on the carbon fiber version.
kdub is offline
Old 06-04-2013, 06:07 PM
  #23
I did a write up a couple of weeks back, track test further down thread too. Hope its helpful for those on fence. Not biased either I'm very happy.
Can't post direct link, could someone do it for me? Its on oople dot com under team associated sub forum.
mainamigo is offline
Old 06-05-2013, 04:30 AM
  #24
MiCk B's Avatar
Link to the B44.1 converted to plus 8mm with the AVID chassis:
http://www.oople.com/forums/showthread.php?t=129236
MiCk B. :-)
MiCk B is offline
Old 06-05-2013, 07:12 AM
  #25
Trader Rating: 21 (100%+)
Is there a place to buy just an Avid chassis protector?
rc10gt82 is offline
Old 06-05-2013, 07:13 AM
  #26
Suspended
I do not think so, but you could try contacting Upgrade-RC and asking if they have any you could purchase.
Old 06-05-2013, 07:14 AM
  #27
Suspended
MiCk B. :-)
Why do you have your transponder on the top deck? Does it effect your lap times with the CF??
Old 06-05-2013, 07:19 AM
  #28
froggie22's Avatar
Yes the AVID chassis is worth it. Noticed a big difference at our outdoor track in AUS. The buggy felt much stabler over the bumps and held on better around the corners. It just felt all round more planted. I had to change my driving style a little bit in some corners since I had more grip than I used too.
As for the protectors, David from AVID said they still aren't sure what direction they want to take that in and to give them a few days to discuss it and determine what they will be doing.
froggie22 is offline
Old 06-05-2013, 07:28 AM
  #29
Thanks froggie. I run on a highly abrasive outdoor track and am looking for something that lasts longer than the Associated and Jconcepts protectors..
Last time out I shredded a Jconcept protector in 2 heats and a main
rc10gt82 is offline
Old 06-05-2013, 11:29 AM
  #30
Isn't everything Avid just plain awesome? :P I'm still drooling over my sc10 steering bellcrank.
Chamelion is offline
