Mod Buggy Gearing
25/78 is what I run with a 13.5 in a B4 with Max boost on a tekin. Blinky I run 28/75
Without knowing the vehicle you are running and it's transmission ratio, along with many other factors. I will simply point you to an absolutely beautiful explanation of the theory that took me 20 years to fully understand.
I just found this yesterday.. no kidding.
http://www.teamassociated.com/pdf/ca...ear_ratios.pdf
Giving you old school advice, GEAR UP. There may be other factors but the motor (at the end of a run) is no more than hot coffee HOT thats an indication to gear up and use the power avaliable thats left in the battery, if the motor is "only" (how did you measure that?) 100 then you are barely warm , then you left some power in the battery that could have been used . Power is heat. In or out it's a concept.
