B4.1 gearing with 17.5 help
What is a good starting point for a 1900kv 17.5 turn motor. I have a hobbyking 60a x car esc along with a 30c battery. Right now i have it at 21/78. Dosent have any low end power and top end is at like 15mph. What gearing should i run for the track island raceway. its indoors search it up on youtube. ANY HELP IS HIGHLY APPRECIATED THANKS!
Check this out, also read the manual...it has gearing recommendations in the back. You will need to be up around the 72/32 range...maybe another tooth or two on the pinion. Also make sure you do a quick search before posting threads...
http://www.rctech.net/forum/electric...4-1-ft-wc.html
http://www.rctech.net/forum/electric...w-threads.html
