Old 05-11-2005, 01:09 AM   #1
Default full throttle cut out
My bandit keeps cuting out whilst i am giving it full throttle. It can be going flat chat then it just stops. If i back off and then give it some again, it goes back to normal. any ideas?
lowndsie is offline   Reply With Quote
Old 05-11-2005, 06:19 AM   #2
jaimzer's Avatar
Send a message via Yahoo to jaimzer
Are yo using the original MSC or an ESC???
What speed control is it??
jaimzer is offline   Reply With Quote
Old 05-12-2005, 03:07 AM   #3
its still got the original MSC.
Old 05-12-2005, 08:10 AM   #4
jaimzer's Avatar
I don't know alot about Mechanical Speed Controls but I would
check to make sure that the servo is not travelling too far.
If the contact is lost you would loose at full throttle.
Hold the car in the air and check the MSC servo operation.
Also make sure the contact surface is clean. (use some contact cleaner) You may have to realign the servo horn.
When you get the funds upgrade to a Electronic Speed Control.
I would recommend the Novak XRS......inexpensive, small size, good quality, reversible, good down to 15 turn motor on 6 cells, you will also get extended run-time with an ESC.
Good luck with it and I hope this helps.
James
Old 05-12-2005, 02:50 PM   #5
thanks for the info. yeah i have a list of mods an arm length long so i'll make sure that i start with an esc.
FULL THROTTLE MOTORSPORTS new2onroad Electric On-Road 25 08-24-2005 11:48 AM
Full Throttle Speedway !!! TimPotter Florida Racing 799 02-27-2005 05:51 PM
full throttle btuner Electric Off-Road 3 04-02-2004 10:17 AM
car going to the right when going full throttle alucard13 Nitro On-Road 14 05-08-2003 02:38 AM
