Team EAM battery, motor and ORCA speedos >
Old 04-28-2013, 12:58 PM
  #46
Team EAM
Trader Rating: 79 (100%+)
Default Spring Sale
From now till May 15th all battery orders will receive free priority mail shipping in the US. Just mention it when contacting me.
The new Saddle packs are in stock along with Shorties.
EA
EAMotorsports is offline
Old 04-28-2013, 01:19 PM
  #47
B00t13g's Avatar
Any eta on more kill shots?
B00t13g is offline
Old 05-15-2013, 08:16 AM
  #48
Team EAM
All 1S, Shorties and Saddle packs on sale for Memorial Day weekend through the end of the month. Not a lot of each left at the moment.
EA
Old 08-15-2013, 03:38 PM
  #49
R/C Tech Elite Member
JayL's Avatar
EA: Killshot T 17.5 2wd Buggy FDR?
JayL is offline
Old 10-29-2013, 08:56 AM
  #50
Message from Electric onroad forum
Originally Posted by noline View Post
Does anyone have a Offroad 2wd setup? for RC10B4.2
Im running a Reedy Sonic 7.5t 20* timing and a LRP X20 7.5t 27.5* timing.
+1 for me with a Yokomo Bmax2 MR with VXX and 7.5 TX ...? (sorry to ask it in the onroad section)
Thx for answer
Jean Alain is offline
Old 10-29-2013, 12:56 PM
  #51
I run the ORCA ESC in my Tamiya TRF201 XM and love it! Very smooth and easy to use programmer. I just wish is was all Aluminum.
Stevenich is offline
Old 10-30-2013, 06:06 AM
  #52
Team EAM
Thx for answer
I do not have a setup to give you for off road at the moment. I am awaiting a reply from the factory for a good starting point.
Are you having an issue with over heating or anything? An all alumn speedo is usually very heavy. The VXX has a larger heat sink and is capable of running large amounts of timing boost and turbo in TC without over heating so I would think it should be fine for all off road classes as well without over heating.
EA
Old 10-30-2013, 10:05 AM
  #53
Thx for this
Old 02-06-2014, 06:35 AM
  #54
I have been using Orca now for half a year and have been really happy. It has worked well. The thing that makes it more impressive is that I use it in my Desc 4wd SC truck combined with a Orcs 6,5t tx Motor! I have tried alot of different combos including the 4 pole HW which seems to be the most popular and changed that out for this ORCA combo and like the ORCA more. Compared to my older ESC:s (HW, Orion, LRP) this feel easier to adjust and very smooth. Also the ESC temperatures are very low, like 40-50 degrees celsius. The motor runs a little hot(which is expected running a 2 pole 540 size motor in 4wd SC) but with the use of motorfan there is no problem! In my dex410 buggy I dont have any problems with temperatures using a Orca 6.5t TX
One thing I have discovered in the orca tx motor( same applies for atleast the older blue HW motors too) is that if you run it too hot a solder on the frontside will melt. If that happens, simply open the screws holding the front cover and solder it back and the motor will work like new again.
Maxxi92 is offline
Old 02-06-2014, 06:52 AM
  #55
jkirkwood's Avatar
EA
He just likes BLING! I've driven his Tamiya and indeed the ORCA ESC is very nice. Tried the OCRA 9.5 this weekend. I found it a bit abrupt on the bottom end for off-road on a slicker track. Are there additional rotors available for the ORCA motors? A 12.1, 12.2 or 12.3? I admit I haven't even looked. Thanks.
jkirkwood is offline
