Losi 22T problem
Old 04-01-2013, 05:19 PM
Default Losi 22T problem
So I just got this 1/10th scale Stadium truck in a trade. After getting it all hooked up with my Transmitter I ran into a problem. While I hold it the tires and everything works great. But when placed on the ground it barley moves. I adjusted the slipper clutch to as tight as I could go and then backed it off a little. But the pinion and spur spin just fine but the drive shafts won't move. Any Idea's?
JoshuaLeClair is offline
Old 04-01-2013, 05:25 PM
Holmberg418's Avatar
Check the tranny. Ball diff might be way to lose. Or idler might be out
Holmberg418 is offline
Old 04-01-2013, 05:32 PM
Suspended
http://www.rctech.net/forum/electric...2t-thread.html
http://www.rctech.net/forum/electric...w-threads.html
pablo040 is offline
Old 04-01-2013, 05:41 PM
ChrisWolfson's Avatar
Hold the spur gear and turn one of he tires. The other tire should spin opposite. If it doesn't, the diff is lose or shot. If the diff works, one of the other gears is stripped or missing.
ChrisWolfson is offline
Old 04-01-2013, 05:43 PM
Sorry I am new.
Old 04-01-2013, 05:44 PM
Originally Posted by JoshuaLeClair
Sorry I am new.
Don't worry about it. Most people are helpful. Some just yell at new people.
Old 04-01-2013, 05:47 PM
Suspended
Sorry I am new.
Don't worry about it. It's a lot easier to get answers if you know where to ask.
Some people like to pretend to be helpful, but will disappear for a week at a time when you need them most.
pablo040 is offline
Old 04-01-2013, 08:52 PM
Or it might be a drive pin in the drive shaft. Or the pin under the hex
Old 04-01-2013, 09:41 PM
AndrewTom's Avatar
first thing is check the diff. did the seller say the diff was just ran through or freshened up?
AndrewTom is offline
