Buggy mod class
Old 04-01-2013, 09:22 AM
  #31
Originally Posted by ifuonlyknew
I was speaking to the guy that started the thread.
yeah i seen it
BlantonBx8 is offline
Old 04-01-2013, 09:34 AM
  #32
Suspended
Originally Posted by BlantonBx8
yeah i seen it
No that other guy you run with responded to my post to you. So, I was explaining to him that I was talking to you.
ifuonlyknew is offline
Old 04-01-2013, 09:37 AM
  #33
t0p_sh0tta's Avatar
Trader Rating: 35 (100%+)
As a counter point, running a mod motor doesn't have to be like dancing with the devil. For a looooong time, I've stayed in the top 3 running a 9.5. I've let plenty of stock guys drive my cars and the first thing out of their mouth is what motor is in it. The answer is that it doesn't matter. "Shut up, and drive it." In 2WD buggy, the throttle should always be used with caution (except for that race winning drag down the straight!). They're surprised at how docile a "mod" car can be if you treat the throttle with a little respect.
t0p_sh0tta is offline
Old 04-01-2013, 09:42 AM
  #34
gticlay's Avatar
Trader Rating: 14 (100%+)
To the OP: Why not try a couple of different motors? You can get the grey can Hobbyking's for $30 and they are plenty fast. Maybe get a 13.5 and a 9.5 so you can experiment a little bit. If you feel the need for a brand name motor, at least you haven't dropped $100 on one and you'll probably know what will work for you at that point. A boosted 13.5 can be super fast if geared properly.
gticlay is offline
Old 04-01-2013, 10:01 AM
  #35
thanks, thats a good POV from someone coming from a 17.5.. i just honestly dont like the whole stock concept. I can try a few different motors to see what does good.
thats a good idea, yeah i seen they have a 10.5 for like 40 bucks! and they are sensored! never really looked into hobbykings products although..
Old 04-01-2013, 10:25 AM
  #36
Trader Rating: 25 (100%+)
For me its not that I cant drive a 7.5 its that I don't like too. Jumping over the tripple and hitting it on the down is a lot harder with a 7.5. I experimented with all different turns before settling on the 8.5. Maybe try a Novak or a Thunder Power motor and buy a few stators. I would do that before buying hobbyking.
chevmaro is offline
Old 04-01-2013, 11:04 AM
  #37
what would be a good gearing set-up for a 9.5t motor?
Old 04-01-2013, 11:08 AM
  #38
t0p_sh0tta's Avatar
With a Tekin gen2, I was running 75/23 with 0-5* of timing on the can. It came off around 120 and there was plenty of room to both gear up, and increase mechanical timing.
Old 04-01-2013, 11:48 AM
  #39
ok cool, thanks
Old 04-01-2013, 12:45 PM
  #40
tekin only makes a 10.5t gen2: with a 5mm shaft? i cant find a 10.5 with 3.18mm anywhere..
Old 04-01-2013, 01:04 PM
  #41
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
huh, a 5mm shaft? are you sure about that? that does not sound right at all.
Wildcat1971 is offline
Old 04-01-2013, 01:07 PM
  #42
Suspended
Amain states otherwise.
Old 04-01-2013, 01:11 PM
  #43
http://www3.towerhobbies.com/cgi-bin...?&I=LXCVMF&P=7
it could be a typo, but it defiently says 5mm.
Old 04-01-2013, 01:13 PM
  #44
http://www.amainhobbies.com/product_...ess-Motor-105T
Amain says differently, and I think/know Tower is wrong
Bearing Dimensions: front: 4x13x5mm rear: 1/8x3/8x5/32"This is from tekins site:
Shaft Dimensions: 3.2mm (1/8") x 15.3mm for ALL of the gen2 motors
Old 04-01-2013, 01:22 PM
  #45
Trader Rating: 37 (100%+)
Wow, before you drop a hundy on a new motor, why don't you use my spare LRP 10.5 for a weekend and see how you like it. You may want more motor and I would hate to see you waste money when a $30 tacon from hobbypartz is all you need for now.
rnpnick is offline
