Agama A8T E-Truggy
I've got one. Use the agama kit. Bolts up perfect. Hop ups aren't needed. I did the new caps and bladders right away for the heck of it.
What is this Agama kit you used, ROSCOE?
Looks like I will have one shortly as well. Got a partial sponsorship with hobby-pro usa. Can't wait till Beta Tires comes out with truggy tires. Do you think the caps and bladders are a good buy or should I try the stock ones first? Anything break that I should keep a couple of in stock? Do you know what the stock caster angle is? Can't wait to get mine bought and set up.
The agama electric conversion part number is agm4002. This kit works with the truck as well as the USA spec buggy chassis. The kit is top notch quality with awesome battery tray (adjustable battery stops to hold battery from sliding) and the motor mount is very similar to the elite rc or losi one.
As far as hop ups. I built mine with a good amount of them from the start but would only suggest the caps and bladders to build a more consistent shock. The diffs are smooth with the stock gears. The stock caps can be machined to work with the convex bladders to save a little cash. The Ackerman plate has broke on some people and others have had no issues. Two fixes for that is the answer rc plate or the losi plate. There is a good amount of info on this unit in the nitro section.
roscoe - do you have video run your e-truggy ?
I will post some pics sometime this weekend guys. No video, sorry. The stock caster blocks are 12 degree btw.
i cant wait to see your picture of e-truggy on post.
Yeah I would like to see pics of this truggy with the conversion. I've been thinking of picking up this truggy for a while now.
Waiting on you Roscoe.....
did you got your agama a8 truggy yet ?
