Associated SC10.2 Factory Team
#1519
Front I'm running yellow avid springs, inner hole on tower, outer on arm, 2mm on camber link and 2mm on bumpsteer.
Rear I went to the white avid spring, 4th hole on tower, inner on arm. A hub, unshaved u-brace with 1 washer.
#1520
I'm loving the sway bar setup, I can drive it really aggressive without fear of the front dumping and unloading the rear. A couple local fast guys drove my truck and loved it. Softest bar on the back and on the front go with the one recommended on the setup sheet with the kit.
Is Good to hear that they work. What kind of track are u on?
#1524
From my experiences, that means the front end is too soft and rolling too much. I run AE red springs in the front and it helped a ton with the rear end unloading. I've ran sway bars to test it, and didn't like them at all.
#1525
I have had great success with the jc swaybar kit. Left my setup alone and added them. I am an average driver and have the fastest laps of the night 2 weeks in a row.
#1526
Anyone run an aluminum front bulkhead at all? Any recommendations on brands? Grub screws?
#1527
I put one on my kids t4. I put an RPM bumper on to protect the arms. Hitting the bumper pulled the screws out of the top plate. Added the aluminum top plate & all was right with the world. He's 10 & doesn't take it seriously at all so I have never bothered to set up the truck properly, so I can't say what the weight does the the balance. I can say the front is all but bullet proof!
edit: oops, I read bulkhead & thought top plate. I installed an aluminum top plate on my sons t4.
#1528
