Tekin Pro 4 HD Factory Thread >
Old 02-13-2017, 10:05 AM
  #736
Thanks a lot! I appreciate it. I'm going to look around. Anyone else have any battery suggestions. Good places to get good battery's cheap. eBay is doing 10% eBay bucks on purchases of 50 or more till feb 15. Thanks again guys appreciate it!
jersey is offline
Old 02-13-2017, 10:06 AM
  #737
jmcelroy42's Avatar
SMC
http://www.smc-racing.net/index.php?...ory&path=67_97
http://www.smc-racing.net/index.php?...product_id=126
jmcelroy42 is offline
Old 02-13-2017, 02:29 PM
  #738
Thanks for the info! Anyone else have any good suggestions on some cheaper good battery's in that range. Thanks again for the info guys it helps a lot.
jersey is offline
Old 02-13-2017, 02:58 PM
  #739
I got 6 smc's and they all work good.
racingnewb is offline
Old 02-13-2017, 11:30 PM
  #740
Thanks! I think I might try the smc since 3 of you guys recommended them. The price isn't bad either. Are hard or soft packs better?
jersey is offline
Old 02-14-2017, 04:14 AM
  #741
jmcelroy42's Avatar
After I found SMC that's all I've bought, Probably bought and sold upwards of 30 different ones. Currently have 9 of them.
Old 02-14-2017, 06:46 AM
  #742
cobrajet's Avatar
I just got a TLR scte 3.0 and plan on running at a track where I do need to run a 2cell but also plan on running it (and more often) at a coworkers home made track where it's race what you brought. The open track is really wide open and it's mostly just freinds and co-workers racing 4x4 Slash's. The question is, if I go with a 3000 HD, how does that compare on a real track running a 2cell vs mostly others running a 4300. And would a 3000 on a 3 cell get get better run times...Like 15 minutes? And what is even a good 3 cell battery?
Sorry, Ive been a nitro head for years, alot of this is new for me.
cobrajet is offline
Old 05-28-2018, 11:44 AM
  #743
Default Pro 4300 gearing and battery.
Why guys, have a losi scte 3.0 with Tekin gen 3 and pro 4300 combo. Could you recommend a pinion size and battery please. Will be running low and high bite
Torchia32 is offline
Old 05-29-2018, 01:30 PM
  #744
DWheels's Avatar
The Pro4 HD 4300 should be ran with the 2S lipo. And 13-15 tooth pinion depending on your track size.
DWheels is offline
Old 05-29-2018, 06:48 PM
  #745
I just put a Tekin rx8 gen2 with a 2500kv pro4hd in my losi SCBE (scte 2.0 with a roll cage) and man itís a torque monster. Itís strictly a basher on 3s and canít wait to get it out on some dirt! Very very pleased
SLO county race is offline
Old 04-18-2019, 07:17 AM
  #746
boudin4evr's Avatar
Trader Rating: 18 (100%+)
who is using a Pro4 HD 1850kv in a Tekno SCT410?
I used to run a Pro4 HD 4300 in my older SCT410
thanks
boudin4evr is offline
Old 04-19-2019, 11:57 AM
  #747
suzukipro's Avatar
Trader Rating: 33 (100%+)
thanks
I've run one in a Super light (pretty much identical to the 410.3) it was a great combination racing against full size buggies in 1/8 buggy class.
Pros:
Smooth power & delivery
lighter weight (compared to 1/8 motors only)
Much cooler operating temps for ESC & motor - Battery too.
Way less stress on battery running 4s compared to 2s due to increased voltage.
Cons:
Wore out the SCT drive train - I ended up having to switch over to the EB48 outdrives and drive shafts due to high wear.
down on power to full sized 1/8 buggy motors on certain longer layouts. *this isn't relevant in a short course though.*
My suggestion: The 1850 is a Great motor and will work, but be prepared to replace driveline components frequently. The PRO HD 4300 is much better suited for short course action and 2s batteries.
suzukipro is offline
Old 09-10-2019, 09:07 PM
  #748
I have a tekin pro4 4000kv and the motor has alot of endplay (in and out) Does anyone know where i can get shims for this motor and how much endplay is acceptable?
Jcnadeau13 is offline
Old 09-11-2019, 04:13 PM
  #749
Team Tekin
Tekin Prez's Avatar
Should be 1mm or less. A little more does not hurt much. Check the rear sensor board screws to make sure they have not come loose and the sensor board has moved to increase the play. We do not offer shims for the 4pole motors as they are not normally needed.
Tekin Prez is offline
