Tekin Pro 4 HD Factory Thread >
Old 03-13-2013, 01:10 AM
  #46
UK.hardcore's Avatar
Originally Posted by teeforb View Post
with SC like tekno sct410 and motors like pro4 HD, keeping it real... isn't this 1/8th scale racing?
No, its 1/9th...
I think 4S should have been the standard for pro-4.
Silly roar and their dumb ideas to run 6lbs trucks on 2S.
UK.hardcore is offline
Old 03-13-2013, 01:34 AM
  #47
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Originally Posted by Rufus2010 View Post
You are changing your story and making up facts to bolster your case.
A T8 weighs less than 3/4 of a pound, not a pound. About 11.6 oz/330grams. Also, you said you wanted to pair up two 7000 mah packs up for a total of 14,000 mah. One 7000 mah pack, with wiring, weighs 12-15oz/360-450grams, depending on brand. You can get light, low mah 4s packs to lighten things up, but that is not what you said.
Edit: I reread your post again, and I understand your position better, but getting down to the weight of an SCT410 would only be realistic with lots of mods and a 3000-4000mah 4s pack.
No problem. Not really true for the weights though. w.r.t. the T8, your again assuming I have the buggy motor. The truggys heavier. Also don't know where you are getting weights for packs I own. I have the promatch 7200 IP packs and they are 308 grams. http://www.promatchracing.com/products.php?cat=38
aloksatoor is offline
Old 03-13-2013, 01:42 AM
  #48
aaron2u's Avatar
Trader Rating: 49 (100%+)
Originally Posted by Randy_Pike View Post
Guys the Pro 4 HD isn't for a 1/8 Buggy. It's for the non ROAR SC racers that like to run the lighter 3s and 4s setups. I tested a 4s 3000mah setup and it runs for DAYS!
For 1/8 E buggy indoor and lighter vehicles we have something "coming soon" for that
We run your 1400kv almost exclusively indoors at Thunder R/C in Nashville TN. So if you need a stomping ground for testing... hit me up!
aaron2u is offline
Old 03-13-2013, 06:32 AM
  #49
ferrarieeeee's Avatar
Its very tempting to put the 4300kv into eb48 for a 2s only setup.......
ferrarieeeee is offline
Old 03-13-2013, 06:50 AM
  #50
Btw can the 4300kv match with hobbywing sctpro or do I need RX8?
Old 03-13-2013, 06:55 AM
  #51
teeforb's Avatar
Trader Rating: 94 (100%+)
I'm assuming it is the 1850kv you are using of 4s. Can u state how many minutes?
When will this be out?
What are the temps on 4s?
Randy, this is a very good thing what tekin is doing. This is what this sport needs. "Some real logical thinking!"
KUDOS!
teeforb is offline
Old 03-13-2013, 06:59 AM
  #52
Hoese37's Avatar
Originally Posted by sramos420 View Post
ba boom!!! Tekin Pro4 HD+Tekno SCT410=DOMINATION!!!
Whoa whoa whoa. Slow your horse. The Tekno isnt the holy grail everyone thinks it is. Tekno fanboys are almost worse than the AE ones.
Hoese37 is offline
Old 03-13-2013, 07:04 AM
  #53
Tech Legend
Cain's Avatar
Trader Rating: 256 (100%+)
+1 . Using the same packs here and have been toying with that idea for my Tekno EB48 as well.
+1 too lol. Main thing, could just share similar setup with my EB48, batteries, and ESC gear.
The main thing I would be curious is there any issue with running this with an ESC that has no problem running the Pro4 4600Kv motor? If not, may be worth a shot.
And to clarify, that may be an easier thing for Tekin to answer or at least have an opinion on versus saying another manufacturers Esc will work with their stuff lol.
Cain is offline
Old 03-13-2013, 07:25 AM
  #54
Team Tekin
Randy_Pike's Avatar
The 4s SC setups just run more efficient, Twice the voltage, half the amp draw. I don't recall run time exactly but I can tell you it wasn't an issue running for 10 minutes.
The Rx8 is the best choice for this motor. I cannot vouch for "other" esc's that may or may not run the motor. IT's likely that if the "other" esc you're using is running a Pro 4 4600 without issue it should run the Pro 4 HD as well.
Randy_Pike is offline
Old 03-13-2013, 07:31 AM
  #55
Tech Legend
Cain's Avatar
fully understand Randy about what you can recommend etc, no sweat.
The RX8 has been the standard bearer for how 4x4 SCT has gone for sure. As a side request, anyway you guys can look into a handheld programmer like several of the other guys have and if you do, can you have it so you can load different firmwares for the ESC on the programmer itself?
Cain is offline
  #56
teeforb's Avatar
When will the motor be out?
teeforb is offline
Old 03-13-2013, 07:45 AM
  #57
Rockthecatbox21's Avatar
Trader Rating: 19 (100%+)
Originally Posted by UK.hardcore View Post
No, its 1/9th...
I don't agree 4s should be the 4wd sct standard. I ran a 3s setup once (2400Kv) and it was awesome. Better than any 2s setup i've tried. More torque, better runtime, less heat, and overall less stress on electronics. 4s is e-buggy's realm, 3s should be perfect to bridge the gap between 2s-1/10, and 4s-1/8. Btw, i ran that 2400Kv setup against 2s setups and i had no more speed than anybody else there. Never outran anybody on the straight, and they didn't outrun me.
Rockthecatbox21 is offline
Old 03-13-2013, 08:25 AM
  #58
teeforb's Avatar
There are not much technical advancements in the 3s relm. Most 3s you can find is around 35C discharge.
I'll be getting the 1850 for sure!
teeforb is offline
Old 03-13-2013, 08:30 AM
  #59
Team Tekin
Randy_Pike's Avatar
@ Cain a hand held programmer? We can do better than that...stay tuned.
Old 03-13-2013, 08:32 AM
  #60
Tech Legend
Cain's Avatar
Will do!
Cain is offline
