Tekin Pro 4 HD Factory Thread >
Old 03-12-2013, 04:39 PM
  #31
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Originally Posted by SEF View Post
So that means you're draining about 550-600mAH for every minute of running. This value is pretty standard for the latest and greatest 4pole power hungry motors. So even when running high capacity lipos in parallel, 25 minutes is probably more realistic.
Yep it will be same if you assume same efficiency. But I am gathering that the longer can will be less heat so more run time or more power to the ground (depending on how you gear). And I want to run the 1850 with 4s not as a 2s.
aloksatoor is offline
Old 03-12-2013, 04:40 PM
  #32
Originally Posted by aloksatoor View Post
Dunno seems possible. If roar removes the silly 7 pound ebuggy rule. I put only 4500mAH back in my 80C 7200 IP lipos after a 6 minute main with 1-2 minutes of warm up now. Pair two of those up, get it close to SCT410 weight and on paper we good .
Interesting proposition. Add 13 to 16 ounces to a vehicle (the weight of the second battery plus the extra wiring) and then expect to make it light.
Rufus2010 is offline
Old 03-12-2013, 04:45 PM
  #33
aloksatoor's Avatar
yep. a t8 weighs around a pound, this is around 250 grams. a t8 already runs with 600 grams plus battery packs, putting two 300 gram 2s packs should be the same weightwise. I am talking about a ebuggy btw
Old 03-12-2013, 04:54 PM
  #34
Team Tekin
Randy_Pike's Avatar
Guys the Pro 4 HD isn't for a 1/8 Buggy. It's for the non ROAR SC racers that like to run the lighter 3s and 4s setups. I tested a 4s 3000mah setup and it runs for DAYS! Mind you the lower Kv's work well on 2s with taller gearing,etc.
For 1/8 E buggy indoor and lighter vehicles we have something "coming soon" for that
Randy_Pike is offline
Old 03-12-2013, 05:42 PM
  #35
justpoet's Avatar
Trader Rating: 16 (100%+)
What is the maximum amps or watts that the 4300kv will pull on 2s?
Trying to get a feel for how this will compare to my 5200kv 550 for power by looking at the specs.
justpoet is offline
Old 03-12-2013, 05:47 PM
  #36
Team Tekin
Randy_Pike's Avatar
The actual amp draw will come down to many outside factors like car weight, gearing,etc.
Old 03-12-2013, 05:51 PM
  #37
You are changing your story and making up facts to bolster your case.
A T8 weighs less than 3/4 of a pound, not a pound. About 11.6 oz/330grams. Also, you said you wanted to pair up two 7000 mah packs up for a total of 14,000 mah. One 7000 mah pack, with wiring, weighs 12-15oz/360-450grams, depending on brand. You can get light, low mah 4s packs to lighten things up, but that is not what you said.
Edit: I reread your post again, and I understand your position better, but getting down to the weight of an SCT410 would only be realistic with lots of mods and a 3000-4000mah 4s pack.
Old 03-12-2013, 05:54 PM
  #38
skengines's Avatar
Trader Rating: 226 (100%+)
Dang. So not ROAR approved? I was going to pick one up too.
skengines is offline
Old 03-12-2013, 06:01 PM
  #39
I will still run them in my SCTE. If I don't I will probably get beat by an SCTE running one lol
I also think that the Pro 2 will be going in my 2wd rigs as well.
fulbore4x4 is offline
Old 03-12-2013, 06:09 PM
  #40
I have nothing against ROAR at all I just can't even remember the last time I raced at a ROAR event. The fact that they aren't ROAR approved really doesn't bother me.
Mark K is offline
Old 03-12-2013, 06:16 PM
  #41
Rockthecatbox21's Avatar
Trader Rating: 19 (100%+)
+1
Rockthecatbox21 is offline
Old 03-12-2013, 08:17 PM
  #42
teeforb's Avatar
Trader Rating: 94 (100%+)
any lower KV for a 4s setup? That's is what i want to target. Even 3s.
teeforb is offline
Old 03-12-2013, 08:18 PM
  #43
teeforb's Avatar
TT2522 - PRO4HD 1850kV
that's my target on 4s
teeforb is offline
Old 03-12-2013, 09:38 PM
  #44
teeforb's Avatar
with SC like tekno sct410 and motors like pro4 HD, keeping it real... isn't this 1/8th scale racing?
teeforb is offline
Old 03-12-2013, 10:22 PM
  #45
sramos's Avatar
ba boom!!! Tekin Pro4 HD+Tekno SCT410=DOMINATION!!!
sramos is offline
