IMAX b6 first use. >
IMAX b6 first use.
IMAX b6 first use.
Old 03-01-2013, 02:17 PM
Default IMAX b6 first use.
Guys
I bought a new IMAX b6 and charging my lipo for the first time after run two of them today on the track and didn't go to cut off.
The lipos are two turnigy 2s 5100 mhp.
It is charging for two hours all ready and didn't finish. Should I worry?
Eran
kavee is offline
Old 03-01-2013, 02:25 PM
Originally Posted by kavee View Post
Guys
Eran
Just finished
kavee is offline
Old 03-02-2013, 03:33 AM
Trader Rating: 55 (97%+)
That charger is rated up to 5a (I believe). If so, it would take at least an hour to charge. Check the manual and it should give you all the information you need. Be careful with how you charge LiPo batteries. Bad things can happen if you don't follow the instructions.
shagnat is offline
